A few questions about the Velox system I orderedPost Date: 2014-11-08 |
redb2112
Newbie Joined: 08 Nov 2014 Online Status: Offline Posts: 1 |
Topic: A few questions about the Velox system I ordered Posted: 08 Nov 2014 at 11:39am |
Hey there, just ordered a Velox system custom build, my first order from Digital Storm, and I had a few questions. First, let me paste my build receipt:
Chassis Model: Special Deal Hot Seller - Digital Storm Velox Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 4790K 4.0 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) Motherboard: GIGABYTE G1.Sniper Z97 (Intel Z97 Chipset) (Onboard Creative Sound) System Memory: 32GB DDR3 1866MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 750W Corsair CX750M Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x SSD (500GB Samsung 840 EVO) Storage Set 2: 1x Storage (3TB Seagate) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x NVIDIA GeForce GTX 980 4GB (Includes PhysX) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex 120mm Radiator Liquid CPU Cooler (High-Performance Edition) H20 Tube Color: - Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Upgrade All Fans to Corsair Airflow Performance Edition (Up to 6 Fans) Internal Lighting: Remote Controlled LED Lighting System (Multiple color options and lighting effects) Airflow Control: Digital Storm Thermal Management Control Board & Software Chassis Mods: - No Thanks Noise Reduction: Noise Suppression Package Stage 1 (Optimized Airflow & Fan Speeds Only) LaserMark: - No Thanks CPU Boost: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Graphics Boost: - No Thanks, Please do not overclock my video card(s) Memory Boost: Memory Fan Kit Only (Does not include memory overclocking service) OS Boost: Yes, Disable and tweak all of the non-crucial services on the operating system Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: APC SurgeArrest Personal PER7 (7 Outlet) 120V Surge Protector Speakers: - No Thanks Keyboard: - No Thanks Mouse: Corsair Vengeance M90 (Laser 5700 dpi) (MMO/RTS Gaming Mouse) (USB Wired) NVIDIA SHIELD: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 4 Year Limited Warranty ( -- PROMOTIONAL LIMITED TIME BONUS DISCOUNT: $125 1 ($125.00) -- PROMOTIONAL LIMITED TIME 1 YEAR WARRANTY UPGRADE ($99 VALUE) 1 $0.00 Then I also ordered seperately off Amazon: Samsung 28-Inch Ultra High Definition LED Monitor (U28D590D) Cable Matters Gold Plated DisplayPort 1.2 to DisplayPort Cable 15 Feet - 4K Resolution Ready Max Keyboard Nighthawk X9 Blue Backlit Mechanical Keyboard (Red Cherry MX) Is this a decent setup? I only went one GTX 980, it broke my heart I didn't have enough to afford an SLI system. But it makes me wonder, is this going to run 4K at 60hz? The Samsung monitor says DisplayPort 1.2 does it, and I think I have a good enough system not to need SLI? I'm hoping I can still set games to max GFX settings and get away with it. Anything I should watch out for with this setup? Any advice would be helpful, thanks! Edited by redb2112 - 08 Nov 2014 at 11:41am |
"Shop smart, shop S-Mart. You got that?!?"
Quote Reply Posted: 08 Nov 2014 at 12:04pm |
Hi redb2112... A single 980 won't play at max settings with 4k. An sli at least is needed, and even then not all games will give you max.
To afford the second card, or at least help, I'd drop to 16gb ram, all gaming needs, drop the lighting and fan upgrade and drop noise reduction package. Drop the memory fan kit, really not needed. Now, all that stuff is really nice but if the budget is stretched I'd go for the performance first. I'm on a tablet so can't compare the price savings compared to another 980. Still might not do it. Also, do you need all the storage? A 256gb SSD and 1Tb HDD might help, but that's your call of course. Good luck. |
Quote Reply Posted: 08 Nov 2014 at 11:40pm |
..and yes, even though you've place the order, should you wish to follow bprat's advice, you can call DS Monday morning after 9pst and discuss any changes or alterations. They are very happy to make this experience the best it can be.
Cheers!
Quote Reply Posted: 10 Nov 2014 at 10:56am |
Hi redb2112,
As usual, bprat22 has given some good advise. If I was you I would put your system on hold until you sort out your requirements. You are going to be disappointed with that monitor and your system. There is no need to have such high resolution and not be able to use it to the fullest. If it was my system I would follow bprat22's suggestions or come up with more money. I would consider getting the 240 rad instead of the 120. The Velox has good cooling and you probable could get by with the 120 with a little higher CPU temp. Personally I want the CPU temp as low as possible. You might also want to step up to a 850 PS. Frank Edited by FrankW - 10 Nov 2014 at 10:57am |
