4k Gaming MachinePost Date: 2014-12-03 |
Mouseguard
Groupie Joined: 17 Jun 2009 Online Status: Offline Posts: 184 |
Topic: 4k Gaming Machine Posted: 03 Dec 2014 at 9:20am |
4000 Expectations: 4k-5k Gaming Usage: Games, Photo Editing Special Needs: [Please Type Here] Saved Ticket #: [Please Type Here] Specifications: Specifications: Chassis Model: Special Deal Hot Seller - Corsair Carbide Series Air 540 Exterior Finish Processor: Intel Core i7 5820K 3.3GHz (Six-Core) (Unlocked CPU) Motherboard: ASUS X99-DELUXE (Intel X99 Chipset) System Memory: 16GB DDR4 2666MHz Corsair Vengeance LPX (High-Performance) Power Supply: 850W EVGA SuperNOVA Storage Set 1: 1x SSD (500GB Samsung 840 EVO) <br><strong></strong> Graphics Card(s): 1x NVIDIA GeForce GTX TITAN Z 12GB (Includes PhysX) Extreme Cooling: H20: Stage 2: Corsair H110 280mm Radiator Liquid CPU Cooler (Extreme-Performance Edition) Chassis Fans: Upgrade All Fans to Corsair Airflow Performance Edition (Up to 6 Fans) Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz |
Baby Bear
Corsair Air 540 i7-6700k @ 4.5 gHz Asus Maximus VIII Hero 16 gb 2666 MHz ram Corsair HX1000i 800 GB Intel 750 series NVM-e (2) GTX 980ti Asus Strix Edition graphics Noctua NH-D15 Cooler |
Quote Reply Posted: 03 Dec 2014 at 9:32am |
Looks like a solid setup! You could go with SLI 980s as well but the Titan Z does have more VRAM.
Also, if you want to play at max/near max settings, you're going to need atleast 3x SLI GTX 980 or 2x Titan Z. Edited by Nav - 03 Dec 2014 at 9:35am |
Quote Reply Posted: 03 Dec 2014 at 9:49am |
Hi Mouseguard.... That is a powerful rig, but 4K is very demanding. Nav nailed it for higher graphics.
Sli 980 would be my pick over the Titan Z. The TitanZ dioes have 6 gb vram vs 4gb vram for the 980's but the 980's seem to bench a little better. Plus newer architecture for the developers. Plus, wattage is lower. . And, if you needed more ooomph, cheaper to add another 980 than another Titan Z. Titan Z is the winner for graphic developers, modeling forecasting, and other heavy computing apps that the Titan was really designed for. My only problem, personally, with a dual gpu card is that if it fails, and warranty doesn't cover it which can happen, you're out a lot more money over a single 980. Plus, the other 980 gives you another card to use if one fails. Have fun. |
Mouseguard
Quote Reply Posted: 03 Dec 2014 at 10:47am |
Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 4790K 4.0 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) Motherboard: ASUS SABERTOOTH Z97 MARK2 (Intel Z97 Chipset) (Military-Grade TUF Components) System Memory: 16GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 850W EVGA SuperNOVA Expansion Bay: - No Thanks Optical Drive: ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST) Storage Set 1: 1x SSD (500GB Samsung 840 EVO) Storage Set 2: - No Thanks Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 980 4GB (Includes PhysX) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Corsair H110 280mm Radiator Liquid CPU Cooler (Extreme-Performance Edition) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Upgrade All Fans to Corsair Airflow Performance Edition (Up to 6 Fans) Mostly for gaming upon further consideration. This might work better for my 4k system... |
Baby Bear
Quote Reply Posted: 03 Dec 2014 at 12:57pm |
Hi Mouseguard,
I see you switched from the X99 system to a Z97 system. The Z97 MB with the 4790k CPU is a great setup for two GPUs. It is not the best choice for more than two GPUs. If think you need a third or forth GPU in the future, you need to go back to the X99 system with a 5820 or 5830 CPU. The Z97 will be PCIe restricted for three GPUs. You could have a bottle neck with the available lanes communicating between the CPU and the GPU. I would take a hard look at how many monitors I will be using and at what resolution. This will tell you how many GPUs and what power supply you need for Max gaming. Your last system is a good build for two GUPs. Frank Edited by FrankW - 03 Dec 2014 at 1:00pm |
Mouseguard
Quote Reply Posted: 03 Dec 2014 at 1:15pm |
Just one monitor, will be a 4k, so I am sort of in limbo about what to get. I don't have enough room for more than one monitor, so will get the best I can. Just want to have enough horsepower to drive my gaming will all the bells and whistles I can get =)
Thanks for the input guys, more decisions =) |
Baby Bear
db188
Quote Reply Posted: 05 Dec 2014 at 4:14pm |
i was watching a video the other day where a guy was testing just how much vram was being used while playing BF4 and other demanding games at 4k on a 2x GTX 980 setup and the usage never even got to 4GB. they were in fact closer to 3GB (it varied from 3.0 to 3.2 GB). sli scales a little differently than xfire. i've seen some tests that showed a pair of 290Xs scaled really well at 4k resolution on certain games. with that said, the new nvidia cards scale nicely as well.
my interpretation is that the Titan Z and other cards that load up on memory won't see huge gains over cards with enough memory and higher clocks. my advice would be to go with 2x GTX 980 (or even 970 if you don't mind turning down some game settings) at 4k gaming. Edited by db188 - 05 Dec 2014 at 4:17pm |
