1st DS purchasePost Date: 2014-03-29 |
Author | |||
DustyRH
Newbie Joined: 29 Mar 2014 Online Status: Offline Posts: 13 |
Topic: 1st DS purchase Posted: 29 Mar 2014 at 7:43pm |
$3,500 Usage: BF4, 1080P, home video editing, Office, music listening Looking for good fps and slight chance might add a 2nd card in the future. Please let me know your thoughts. Thanks very much! Configuration Code: 941878 Total Price with Instant Savings: $3,289 Specifications: Chassis Model: Special Deal Hot Seller - Corsair Obsidian 550D Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 4930K 3.4GHz (Unlocked CPU for Extreme Overclocking) (Six-Core) Motherboard: ASUS Sabertooth X79 (Intel X79 Chipset) (Features USB 3.0 and SATA 6Gb/s) System Memory: 16GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested)- Power Supply: 850W Corsair RM Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) - Storage Set 1: 1x (250GB Solid State - Samsung 840 EVO) Storage Set 2: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x NVIDIA GeForce GTX 780 Ti 3GB (Includes PhysX) Sound Card: Creative Sound Blaster Z - HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex 120mm Radiator Liquid CPU Cooler (High-Performance Edition) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: Noise Suppression Package Stage 1 (Optimized Airflow & Fan Speeds Only) LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 8.1 (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: - No Thanks Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Portable Gaming: - No Thanks Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Large |
Quote Reply Posted: 30 Mar 2014 at 7:29am | ||
Hi DustyRH... Welcome to the forums.
That is an excellent build. The only though is that you could save almost $300 by starting with level 2 and getting the I7-4770k with Z87 Sabertooth. But, that depends what level editing you do. Your build's 6 core cpu and quad channel ram helps with heavier video editing, Light Room, heavy multi-tasking, etc. Not much with games although some newer games are just starting to use more cores, but not a big difference in performance. It is in the budget so keeping the 4930k doesn't hurt. Nice rig you put together. |
Quote Reply Posted: 30 Mar 2014 at 8:11am | ||
I agree with what bprat22 said about the Ivy Bride-E (Extreme/Enthusiast) vs Haswell (Desktop) architectures. One additional difference is the support for the latest generation ports. The Extreme systems only have 2 SATA 6Gbps on the PCH (aka chipset) and no USB 3.0 though those are added with 3rd party chips.
It is a bit more, but you get a longer warranty with the 840 Pro 256GB over the 840 Evo 250GB. Performance differences will depend on your work load. Here is a review that shows them each in benchmarks: http://www.anandtech.com/show/7173/samsung-ssd-840-evo-review-120gb-250gb-500gb-750gb-1tb-models-tested. Edited by danjw1 - 30 Mar 2014 at 8:12am |
DustyRH
Quote Reply Posted: 30 Mar 2014 at 9:20am | ||
Thank you both for your input. The video editing is moderate and I'm not adverse to saving some money. Please check my configuration edit to see if I should tweak anything else. Thanks again!
Configuration Code: 942030 Total Price with Instant Savings: $2,992.00 Specifications: Chassis Model: Special Deal Hot Seller - Corsair Obsidian 550D Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 4770K 3.50 GHz (Unlocked CPU) (Quad Core) Motherboard: ASUS Sabertooth Z87 (Intel Z87 Chipset) (Features Thermal Armor and Thermal Radar) System Memory: 16GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 850W Corsair RM Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x (256GB Solid State - Samsung 840 Pro) Storage Set 2: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x NVIDIA GeForce GTX 780 Ti 3GB (Includes PhysX) Sound Card: Creative Sound Blaster Z HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex 120mm Radiator Liquid CPU Cooler (High-Performance Edition) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: Noise Suppression Package Stage 1 (Optimized Airflow & Fan Speeds Only) LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 8.1 (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: - No Thanks Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Portable Gaming: - No Thanks Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Large) Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) |
Quote Reply Posted: 30 Mar 2014 at 9:24am | ||
Excellent. I say, go for it.
Quality parts and lots of bang for the buck. Stay in touch. |
Quote Reply Posted: 30 Mar 2014 at 10:16am | ||
Looks great!
Dakota Red
Groupie Joined: 08 Jun 2013 Online Status: Offline Posts: 121 |
Quote Reply Posted: 30 Mar 2014 at 6:47pm | ||
Great build DustyRH, I don't think you need to change a thing.
Welcome to the DS Forums. |
Performance matters. Non-Performance is not an option.
fstcvc
Quote Reply Posted: 31 Mar 2014 at 12:46am | ||
Looks like a solid build form here... And welcome to DS!!
HailStorm II
Quote Reply Posted: 31 Mar 2014 at 12:00pm | ||
That looks like a very solid build! All high quality components!
If you do think you are going to want a second graphics card in the future, I would bump the PSU to 1000W+. I would suggest with the 1050W Corsair HX of the 1000W Silverstone Strider. The Strider is 80 Plus Gold vs Silve for the HX. So, the Strider is the more efficient. Edited by danjw1 - 31 Mar 2014 at 12:01pm |
DustyRH
Quote Reply Posted: 31 Mar 2014 at 1:16pm | ||
Changed to the Strider just in case I add the 2nd card later.
New code #942538. Thanks! |
DustyRH
Quote Reply Posted: 31 Mar 2014 at 6:46pm | ||
As I mentioned above, I increased the power supply to 1000W. Now I am considering adding the 2nd 780Ti now instead of later.
Is everything else ok in the system with adding the 2nd card - cooling, etc. the way it is configured on code #942694??? I appreciate all of your comments. Thanks! Edited by DustyRH - 31 Mar 2014 at 7:53pm |
fstcvc
Quote Reply Posted: 31 Mar 2014 at 9:55pm | ||
HailStorm II
Dakota Red
Quote Reply Posted: 01 Apr 2014 at 9:18pm | ||
I think everything should be ok to add a second GTX 780i because they are both reference design cards that push most of their heat (if not all) to the outside of the case. If you want to be on the safe side you could for $30 more upgrade your cooler to the 240m radiator. That is what I did with my Slade so I could upgrade in the future and not worry about the smaller rad being overwhelmed.
Welcome to the DS Forums and I hope you buy a DS Slade. It is really a great computer. |
Quote Reply Posted: 02 Apr 2014 at 1:48pm | ||
That might be better, since that would be mounted on the top, clearing the rear exhaust port. The rear exhaust fan is the only thing pulling hot air out of the case. It might also be a good idea to ask DS to up the rear exhaust fan to a 140 high airflow fan. Another thought is for less than the cost of the audio card you could probably get DS to special order the Maximus VI Formula rather then the Sabertooth. It has an isolated audio section, ROG armor (like the thermal armor of the Sabertooh), built in WiFi and other ROG features that would be nice to have. |
Counsel
Quote Reply Posted: 02 Apr 2014 at 5:41pm | ||
One quick note - adding a 240mm radiator will require opening the top of the case, which will let out more noise. It'll still be a quiet system, just not the maximum-quiet standard configuration. That said, I believe that opening the top or side is probably unavoidable if you want to go SLI. Two cards put out a lot of heat, even if you go with NVIDIA's excellent blower-style reference cooler on both of them. |
DustyRH
Quote Reply Posted: 02 Apr 2014 at 6:46pm | ||
So if I have this correct, using the Slade and going with 2 cards I need 1000 watts, 240mm radiator, upgraded fans and I have to open one of the case sides Maybe 2 cards aren't worth it??? I'm getting confused. |
Clay
Quote Reply Posted: 02 Apr 2014 at 7:19pm | ||
Nice... very nice! Welcome to DS!!
I7 13700KF 5.4hz
Quote Reply Posted: 03 Apr 2014 at 8:05am | ||
Actually, I wouldn't suggest covering the one exhaust outlet with a radiator for any build. You need someway to exhaust heat from the case. The other option is to go with an air cooler for the CPU instead. Edit: The Slade case is designed to offer flexible cooling. One option is to adjust it to the workload. Adding fans, but keeping the covers on for light workloads is an option. Asus motherboards come with a utility that can control the fans based on CPU temperature in software. With the utility you can control at what temperatures the fans start/stop and what the angle of the rpm curve is. Another thing to think about would be to add fan(s) to the left side panel ports, assuming those would face away from you. That motherboard has 8 fan headers and it is very easy to add them yourself (4 screws and one power line). Edited by danjw1 - 03 Apr 2014 at 12:09pm |
Quote Reply Posted: 04 Apr 2014 at 7:46am | ||
Actually, here is a review of that case, it might help you better understand my point: http://www.anandtech.com/show/5708/corsair-obsidian-550d-starting-to-specialize
DustyRH
Quote Reply Posted: 04 Apr 2014 at 5:39pm | ||
Thank you to all for your information and support!
Along with the forums, the tech support personnel and sales support have been extremely helpful and fast in response time! Placed the order this afternoon and already in stage 3! Slade: ($3,167) Chassis Model: Corsair Obsidian 550D Processor: Intel Core i7 4770K 3.50 GHz (Unlocked CPU) (Quad Core) Motherboard: ASUS Sabertooth Z87 (Intel Z87 Chipset) (Features Thermal Armor and Thermal Radar) System Memory: 16GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 1050W Corsair Pro Silver 1050HX (Dual/Triple/Quad SLI Compatible) Expansion Bay: Internal Digital Media Card Reader (Black) Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x (256GB Solid State - Samsung 840 Pro) Storage Set 2: 1x Storage (2TB Western Digital - Black Edition) Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x NVIDIA GeForce GTX 780 Ti 3GB (Includes PhysX) Sound Card: Creative Sound Blaster Z Extreme Cooling: H20: Stage 2: Digital Storm Vortex 120mm Radiator Liquid CPU Cooler (High-Performance Edition) Chassis Fans: Standard Factory Chassis Fans Noise Reduction: Noise Suppression Package Stage 1 (Optimized Airflow & Fan Speeds Only) CPU Boost: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Windows OS: Microsoft Windows 8.1 (64-Bit Edition) Thanks again! |
Counsel
Quote Reply Posted: 04 Apr 2014 at 6:48pm | ||
Congrats, and welcome to the family!
Let us know if you hit any snags - DS is pretty quick with their customer service, but you can often get advice here even faster, especially outside of business hours. I know I did when my Slade arrived and I was plugging my monitor in incorrectly... |
Clay
Quote Reply Posted: 04 Apr 2014 at 8:03pm | ||
Again!!
I7 13700KF 5.4hz
fstcvc
Quote Reply Posted: 04 Apr 2014 at 10:21pm | ||
Congrats on your new machine!!
HailStorm II
DustyRH
Quote Reply Posted: 07 Apr 2014 at 1:02pm | ||
In Stage 5 and it's only been 1 1/2 business days!
Edited by DustyRH - 09 Apr 2014 at 6:27pm |
DustyRH
Quote Reply Posted: 09 Apr 2014 at 6:31pm | ||
Just heard my rig has shipped and it was after only 3 1/2 business days!
Quote Reply Posted: 10 Apr 2014 at 12:48am | ||
fstcvc
Quote Reply Posted: 10 Apr 2014 at 8:37am | ||
The wait is almost over...
HailStorm II
Theokritos
Quote Reply Posted: 10 Apr 2014 at 11:48am | ||
Quote Reply Posted: 13 Apr 2014 at 3:14pm | ||
Congratulations! I hope you enjoy your new system. Please post some a short review and some photos, once you had a chance to play with it for a while, in the General forum. ;-)
Clay
Quote Reply Posted: 13 Apr 2014 at 4:19pm | ||
I7 13700KF 5.4hz
UffDa
Newbie Joined: 01 Apr 2014 Online Status: Offline Posts: 59 |
Quote Reply Posted: 13 Apr 2014 at 7:27pm | ||
i7 4930K 4.3GHz OC
ASUS Rampage IV Extreme 32GB DDR3 1866MHz Corsair Vengeance Pro 256GB SSD Samsung 840 Pro 2TB WD Caviar 2xSLI GeForce GTX 780 3GB EVGA Superclocked |
