1400 build
Post Date: 2013-11-23
Veezu View Drop Down
  Quote Veezu Quote  Post ReplyReply bullet Topic: 1400 build
    Posted: 23 Nov 2013 at 1:16pm
$1400 INCLUDING mouse, keyboard, +monitor
handle high settings
League, Dota2, Starcraft on medium-highest settings
I was planning on getting bolt level 1 or vanquish level 3? any recommendations?
Nav View Drop Down
Digital Storm Employee
  Quote Nav Quote  Post ReplyReply bullet Posted: 23 Nov 2013 at 3:01pm
The Bolt Lv 1 will allow you to have a more portable machine while the Vanquish Lv 3 will give you a slightly larger chassis for any future upgrades you might want to do. The Lv. 3 Vanquish might be your best option as it allows you a buffer to get a keyboard/mouse + monitor to stay within your budget.
This page was generated in 4.101563E-02 seconds.
