\3\LXCCtime.dll
Post Date: 2012-09-27
THX1138 View Drop Down
  Quote THX1138 Quote  Post ReplyReply bullet Topic: \3\LXCCtime.dll
    Posted: 27 Sep 2012 at 12:46pm
Anyone know if OK to remove? Comes on @ start up. Google says take pick :ignore , dangerous , harmless. Thanks everyone. I,m the worlds oldest NOOB. Hey, I was smart enough to get Digital Storm.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 27 Sep 2012 at 1:18pm
Hi THX1138,
This is what I found on Windows Answers.
"LXCTtime.dll is a Lexmark printer file. Program starts upon Windows startup. It is not a Windows system file.
If you have a lexmark printer, (or other Lexmark product) try to reinstall it."
If you have a Lexmark Printer then you probably need that file. If you don't have one, I would check my Start file to make sure it is not listed as a start up program. For some reason your computer may be trying to start the printer program and you don't have it.
Check Here.
Go into msconfig and make sure there are no Lexmark programs checked.
Edited by FrankW - 27 Sep 2012 at 1:22pm
  Quote THX1138 Quote  Post ReplyReply bullet Posted: 27 Sep 2012 at 8:17pm
THANKS FrankW, I ended up installing new driver for my Lexmark printer. Worked like a charm.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 28 Sep 2012 at 6:18am
Glad to help.
This page was generated in 4.418945E-02 seconds.
