X79 build helpPost Date: 2011-11-16 |
AKleetness
Newbie Joined: 29 Mar 2011 Online Status: Offline Posts: 16 |
Topic: X79 build help Posted: 16 Nov 2011 at 6:16pm |
woohoo x79 is finally here been waiting for this. I could use some help with a pure gaming build. i will be gaming on a dell 30" at 2560x1600.
would like to keep the price around $4000.
Thanks alot for the help.
DST4ME
Quote Reply Posted: 16 Nov 2011 at 6:39pm |
Here you go Ticket# 618423 --- $3,876 (To see this build click here)
Copy of Specifications: Chassis Model: Special Deal Hot Seller - Cooler Master 942 HAF X Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 3930K 3.2GHz (Unlocked CPU for Extreme Overclocking) (Six-Core) Motherboard: ASUS P9X79 DELUXE (Intel X79 Chipset) (Features USB 3.0 and SATA 6Gb/s) System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 1200W Corsair Pro Gold Series (CMPSU-1200AX) (Dual/Triple/Quad SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Intel) (Model: 320 Series) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 2x SLI Dual (NVIDIA GeForce GTX 570 2.5GB (PhysX) (EVGA 025-P3-1579-AR) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 2: Noctua NH-D14 Extreme Performance (Does NOT fit on the regular EVGA X58 3X SLI) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Red) Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires Pro or Deluxe Series Motherboard) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 5-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 5 Year Limited Warranty this system is setup to handle tri sli tho it has dual, this is so that if you see you need more gpu power for some of your game, you have the option to go tri sli, keep in mind the third card makes the least difference. Ask DS specifically for this fan to be added to the top, so you endup with 4 x 200mm fans: haf 200mm non led fan I uped your warranty to 3 year part (5 year labor) so that if you vcore is high and cpu dies within 2 years you are covered. if you don't want tri sli ability, we can go to p67 and save a bunch. Edited by DST4ME - 16 Nov 2011 at 6:42pm |
AKleetness
Quote Reply Posted: 16 Nov 2011 at 7:40pm |
Thanks for the build DST. Well i kinda been waiting for the x79 because i wasnt sure if the p67 would handle the monitor and it would be a shame to not use it to its fullest correct?
DST4ME
Quote Reply Posted: 16 Nov 2011 at 7:47pm |
Depends on the game, for some games you may want to try tri sli for some games dual sli 570 2.5GB is all you need, for that reason I gave you only 2, you may just find out you don't need the third card, or you may want it for some games.
AKleetness
Quote Reply Posted: 16 Nov 2011 at 7:57pm |
alrighty well i guess the x79 will be best then might as well go with it since i waited for it . lol
DST4ME
Quote Reply Posted: 16 Nov 2011 at 8:00pm |
Don't forget to post review and pics of it when you get it
AKleetness
Quote Reply Posted: 16 Nov 2011 at 8:02pm |
Of course
neilkaz
Groupie Joined: 02 Mar 2010 Online Status: Offline Posts: 156 |
Quote Reply Posted: 17 Nov 2011 at 5:01pm |
A rocking build from DST as always !! This machine should be incredible for gaming.
I am just curious from a pure overclock speed standpoint can anything be gained by going with the more expensive i7 3960K chip rather than the i7 3930K or will the end result of the O/C basically be the same?
thx .. neilkaz ..
HAF932
i7-980X at 4.34 Ghz HT 24/7 GTX 275 6 MB STT DDR3 at 1628 MHz Stage 4 cooling |
DST4ME
Quote Reply Posted: 18 Nov 2011 at 12:40am |
You mean 3960x vs 3960k right?
if you are ocing under 5GHz its the same, but at around 4.8Ghz you gonna get into high vcore anyways. Edited by DST4ME - 18 Nov 2011 at 12:40am |
