X79 build help
Post Date: 2011-11-16
AKleetness View Drop Down
  Quote AKleetness Quote  Post ReplyReply bullet Topic: X79 build help
    Posted: 16 Nov 2011 at 6:16pm
woohoo x79 is finally here been waiting for this. I could use some help with a pure gaming build. i will be gaming on a dell 30" at 2560x1600.
would like to keep the price around $4000.
Thanks alot for the help.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Nov 2011 at 6:39pm
Here you go Ticket# 618423 --- $3,876 (To see this build click here)
Copy of Specifications:
Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Intel) (Model: 320 Series)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 570 2.5GB (PhysX) (EVGA 025-P3-1579-AR)
Extreme Cooling: AIR: Stage 2: Noctua NH-D14 Extreme Performance (Does NOT fit on the regular EVGA X58 3X SLI)
Warranty: Life-time Expert Customer Care with 5 Year Limited Warranty
this system is setup to handle tri sli tho it has dual, this is so that if you see you need more gpu power for some of your game, you have the option to go tri sli, keep in mind the third card makes the least difference.
Ask DS specifically for this fan to be added to the top, so you endup with 4 x 200mm fans:
haf 200mm non led fan
I uped your warranty to 3 year part (5 year labor) so that if you vcore is high and cpu dies within 2 years you are covered.
if you don't want tri sli ability, we can go to p67 and save a bunch.
Edited by DST4ME - 16 Nov 2011 at 6:42pm
  Quote AKleetness Quote  Post ReplyReply bullet Posted: 16 Nov 2011 at 7:40pm
Thanks for the build DST. Well i kinda been waiting for the x79 because i wasnt sure if the p67 would handle the monitor and it would be a shame to not use it to its fullest correct?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Nov 2011 at 7:47pm
Depends on the game, for some games you may want to try tri sli for some games dual sli 570 2.5GB is all you need, for that reason I gave you only 2, you may just find out you don't need the third card, or you may want it for some games.
  Quote AKleetness Quote  Post ReplyReply bullet Posted: 16 Nov 2011 at 7:57pm
alrighty well i guess the x79 will be best then might as well go with it since i waited for it . lol
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Nov 2011 at 8:00pm
Don't forget to post review and pics of it when you get it
  Quote AKleetness Quote  Post ReplyReply bullet Posted: 16 Nov 2011 at 8:02pm
Of course Big%20Smile
neilkaz View Drop Down
  Quote neilkaz Quote  Post ReplyReply bullet Posted: 17 Nov 2011 at 5:01pm
A rocking build from DST as always !! This machine should be incredible for gaming.
I am just curious from a pure overclock speed standpoint can anything be gained by going with the more expensive i7 3960K  chip rather than the i7 3930K  or will the end result of the O/C basically be the same?
thx .. neilkaz ..
HAF932
i7-980X at 4.34 Ghz HT 24/7
GTX 275
6 MB STT DDR3 at 1628 MHz
Stage 4 cooling
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Nov 2011 at 12:40am
You mean 3960x vs 3960k right?
if you are ocing under 5GHz its the same, but at around 4.8Ghz you gonna get into high vcore anyways.
Edited by DST4ME - 18 Nov 2011 at 12:40am
This page was generated in 0.1015625 seconds.
