wiring inside the case
Post Date: 2009-03-01
dude View Drop Down
  Quote dude Quote  Post ReplyReply bullet Topic: wiring inside the case
    Posted: 01 Mar 2009 at 6:35pm
so if i order from ds would i have to wire anything inside the computer or is it just take out the foam and plug and play? sorry am a noGeekob Smile
THE BOSS
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 01 Mar 2009 at 6:38pm
gently take the foam out, check and make sure nothing is loose, once you are sure things are all good, close it up, plug it into the wall and give it ago
