Will this work?Post Date: 2014-10-04 |
saqib126
Newbie Joined: 04 Oct 2014 Online Status: Offline Posts: 8 |
Topic: Will this work? Posted: 04 Oct 2014 at 12:22pm |
Will this work? As in, is it compatible, do I need more power, do I need more cooling, and other suggestions.(like if there is a much better video card or something around the same price)Here is what I have settled on, for now. My budget: I`m already over and I`d like to reduce costs but I don`t want to compromise.
Chassis Model: Special Deal Hot Seller - Digital Storm Apollo Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 4790K 4.0 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) Motherboard: ASUS MAXIMUS VII HERO (Intel Z97 Chipset) (The Ultimate Power Platform) <br><strong></strong> System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 750W Corsair CX750M Expansion Bay: Dual Solid State Hard Drive Hot Swap Bay Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x Storage (1TB Seagate) Storage Set 2: - No Thanks Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x NVIDIA GeForce GTX 970 4GB (Includes PhysX) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Corsair H110 280mm Radiator Liquid CPU Cooler (Extreme-Performance Edition) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Upgrade All Fans to Corsair Airflow Performance Edition (Up to 6 Fans) Internal Lighting: Internal Chassis Lighting System (Blue) Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: Acer 24 inch (Widescreen) (Black) (High-Performance Gaming Display) Surge Shield: APC SurgeArrest Personal PER7 (7 Outlet) 120V Surge Protector Speakers: Logitech 2 Piece (Black Edition) Amplified Speaker Set Keyboard: CM Storm Devastator Bundle (Gaming Keyboard & Gaming Mouse) Mouse: - No Thanks Portable Gaming: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) Edited by saqib126 - 04 Oct 2014 at 6:03pm |
Quote Reply Posted: 05 Oct 2014 at 5:35am |
Hi saqib126... Welcome to the forums.
That looks like a real nice rig. The gtx 970 is one of the best and even though the 980 is about 10-20% better frames, it is a lot more $$ for the added performance. The 970 is a best bang for your buck, especially on a 24" at 1920x1080 resolution. You didn't mention its purpose, but if its for gaming only, you could save $130 and go with the i5-4690k cpu. The i7-4790k does have hyperthreading for high multi-tasking, etc but doesn't do much for gaming as of right now. The i7 does have a higher base and turbo clock speed, but with overclocking it doesn't matter much. For a tight budget, go with the i5, otherwise the i7 is never a bad idea. The Seagate HDD I would change to the Western Digital Black for another $19. A better unit with longer warranty. Hope this helps and good luck. |
saqib126
Quote Reply Posted: 05 Oct 2014 at 7:01am |
thanks for the suggestions!
Quote Reply Posted: 05 Oct 2014 at 7:07am |
My pleasure.
Quote Reply Posted: 05 Oct 2014 at 8:38am |
If you can swing it within your budget, you may want to consider an SSD for your boot drive. 240/256 MB seems to be the sweet spot for most people. Other than that, what bprat22 said. ;-)
Ariktu
Quote Reply Posted: 05 Oct 2014 at 10:00am |
This is the system I would probably go with.
Configuration code: 1058950 for $2172. Chassis Model: Special Deal Hot Seller - Digital Storm Apollo Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i5 4690K 3.50 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) Motherboard: ASUS SABERTOOTH Z97 MARK2 (Intel Z97 Chipset) (Military-Grade TUF Components) System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 750W Corsair CX750M Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x SSD (256GB Samsung 850 PRO) Storage Set 2: 1x Storage (1TB Western Digital - Black Edition) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x NVIDIA GeForce GTX 970 4GB (Includes PhysX) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Corsair H100 Liquid CPU Cooler (240mm Radiator) (Extreme-Performance Edition) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Upgrade All Fans to Corsair Airflow Performance Edition (Up to 6 Fans) Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Portable Gaming: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) I would buy my monitor and speakers and keyboard, mouse likely somewhere else. although you can add those in of course. Edited by Ariktu - 05 Oct 2014 at 10:02am |
