Will I experience any problems? AMD with NvidiaPost Date: 2014-11-11 |
rebelsrwe
Newbie Joined: 11 Nov 2014 Online Status: Offline Posts: 1 |
Topic: Will I experience any problems? AMD with Nvidia Posted: 11 Nov 2014 at 6:15pm |
[$1250] Expectations: Play all games on high or ultra. Ability to upgrade in the future. The config is 1091819 I want everyones opinion on the set up. I had no choice other than AMD processors I would much rather have an Intel but will this processor cause issues when paired to my gpu I have chosen? |
Quote Reply Posted: 12 Nov 2014 at 5:13am |
You can mix AMD cpu with Nvidia cards. Unless you want to use that A10 chips integrated gpu, not likely with the seperate gtx 970, I would change to the fx 6350 or 8320. More cores and better performing than that A10 from benches I've seen.
Good luck. |
Quote Reply Posted: 12 Nov 2014 at 6:20am |
Yep, bprat22 is right there shouldn't be any problem.
I don't think there should a an issue if you decided to use the integrated GPU of the CPU for a secondary monitor, though I wouldn't want to run a game across the two monitors. So, if you wanted a secondary display to browse the web while playing games, I believe that would work. |
