Wi-fi adapters for VanquishPost Date: 2014-09-16 |
croctopus
Newbie Joined: 10 Aug 2014 Online Status: Offline Posts: 10 |
Topic: Wi-fi adapters for Vanquish Posted: 16 Sep 2014 at 7:54am |
I recently bought a Vanquish lvl 4 that is arriving in a couple of days and I'm looking for a good wi-fi adapter. I am looking at the Asus - 802.11n PCI Express Wi-Fi Adapter. It says it gets speeds of up to 300mbps. Does anyone know if this is a good adapter or does anyone have any recommendations?
Quote Reply Posted: 16 Sep 2014 at 8:10am |
That should work just fine. If you don't want to open the case and install into the motherboard, you can also use a USB WiFi adapter that just mounts externally. The Netgear N300, D Link N 150, etc are all decent.
So many to choose from and everyone has their favorite. An internal card or external USB are really your choice. Good Luck. |
Razorback
Groupie Joined: 18 Aug 2014 Online Status: Offline Posts: 99 |
Quote Reply Posted: 16 Sep 2014 at 10:38am |
I have a Cisco usb and it works great. I am pretty sure that there isn't really much of a difference. Go with the brand you want/trust and you should be good.
Intel Core i7 6700k 4.5 GHz (OC)
ASUS Maximus Hero VIII 16GB DDR4 3200 MHz 120GB Samsung 840 EVO 250GB Samsung 840 EVO 1TB Seagate (7200 RPM) (64MB Cache) 1x NVIDIA GeForce GTX 1080 8GB |
Rockcem
Newbie Joined: 09 Aug 2014 Online Status: Offline Posts: 86 |
Quote Reply Posted: 16 Sep 2014 at 11:21am |
*The Beast Has been Acquired*
Quote Reply Posted: 16 Sep 2014 at 12:58pm |
I use the Netgear N300 for my Vanquish 4. It was a "I need it NOW" kind of purchase and it's been just fine for gaming and Netflix.
croctopus
Quote Reply Posted: 16 Sep 2014 at 2:01pm |
Ok thanks. I ended up getting a Netgear N600. Hopefully it will work well for downloading all of my games.
Quote Reply Posted: 16 Sep 2014 at 2:18pm |
Ariktu
Quote Reply Posted: 17 Sep 2014 at 11:00am |
I am currently using a TP-Link TL-WN822N N300 wireless adapter which was pretty inexpensive. I think it was under $20.
I am pretty far from the Router and at one point tried a N600 netgear adapter and it got a worse signal than the TP-Link for some reason. I ended up realizing my comcast router built in sucked so switched to an Asus RT-N66W N900 router and my issues went away. I stayed with the TP figuring it was cheaper and worked although maybe it will give me issues in longevity in which case I might switch to the netgear adapter I still have. |
