Hello I am still saving money for my dream computer. I would like advice and recommendations.
I will be planning to buy a 1 Dell 30" monitor 2560 X 1440 or
Recommend another 30" monitor which is similar in resolution and size.
I would like to experience totally emersive game play.
I enjoy FPS
I will buy bf3 once I get the computer. I would like to playthe game on ultra with highest frame rate possible no lag.
I will try metro 2033 also later on
Also do general web surfing
no video rendering
No fancy video editing
Just Gaming computer
Budget= $3500.00 + or - $300.00
Which configuration would be best for my situation
Will the slade desktop work or
should i go for the Haf x
Did I select the right hardware given the type of monitor I plan to buy?
Please recommend other options if necessary.
Thank you for looking over the two configurations that I worked out
Configuration 1: 695415
configuration 2: 695420
