What happens if you choose no hard drive?
Post Date: 2012-05-09
isaidicanshout View Drop Down
  Quote isaidicanshout Quote  Post ReplyReply bullet Topic: What happens if you choose no hard drive?
    Posted: 09 May 2012 at 4:01pm
Just wondering, what happens if you choose "no thanks" on all hard drive options? I can't remove the OS from the system, so do you just receive a packaged version on the side? Is the system tested with an existing hard drive and then shipped without one? Is the system assembled but not tested because there is no boot drive?
  Quote Alex Quote  Post ReplyReply bullet Posted: 09 May 2012 at 5:41pm
We use a DS hard drive, but, honestly, I would at least pick a cheap basic drive, they aren't that expensive and allows us to fully test a system for you.
  Quote isaidicanshout Quote  Post ReplyReply bullet Posted: 10 May 2012 at 10:22am
well i would ideally use a 128GB SSD, except if the base 500GB HD is $114 and the 120 SSD is +$96 then that means your 120 SSD is $210 when I could get a 128GB Crucial M4 for $125.
obviously things cost a bit more when they're professionally handled and installed, and i'm fine with that because you're known for quality builds, but that's a very significant price hike for a component that doesn't require the finesse of an overclocked CPU or GPU.
z3r0 View Drop Down
  Quote z3r0 Quote  Post ReplyReply bullet Posted: 14 May 2012 at 7:01pm
you could get an SSD later and just clone the main drive to it. Get a storage drive as a primary for the build, clone to your SSD and then use the HD as a secondary afterwards...
This page was generated in 0.1757813 seconds.
