wedding present
Post Date: 2009-11-26
Aceboy View Drop Down
  Quote Aceboy Quote  Post ReplyReply bullet Topic: wedding present
    Posted: 26 Nov 2009 at 11:42am
Next to a marriage had a chance to spend for my dreams rig, what is your ideas abouts that project?
Copy of Specifications:
Chassis Model: Lian Li PC-P80B (Black OPS Edition)
Trim Accents: Paint All Trim Accents: Chassis Vents, Grills, Screws, and Hose Clamps (Red)
Processor: Intel Core i7 Extreme Edition 975 3.33GHz (Quad Core) (Extreme Performance)
Motherboard: EVGA X58 Classified 4X SLI (Intel X58 Chipset) (Requires Lian Li PC-P80B Chassis)
System Memory: Corsair XMS3 Dominator GT CMG6GX3M3A2000C8 6GB DDR3 3X2GB DDR3-2000 CL 8-8-8-24 Core i7 Memory Kit (12 gb may have sanse?)
Power Supply: 1250W Enermax Galaxy EVO (Dual/Triple/Quad SLI Compatible) (Recommended)
Expansion Bay: Internal Digital Media Card Reader (Black)
Hard Drive Set 1: Operating System: 2x (256GB Solid State (By: Corsair) (Model: CMFSSD-256D1)
Set 1 Raid Options: Configure All HDD Sets 1, 2, and 3 to a Raid JBOD Config - Combine HDDs to Single Virtual Volume
Hard Drive Set 2: Multimedia\Data: 2x (1TB Seagate/Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme
Hard Drive Set 3: Backup\Misc.: 2x (1TB Seagate/Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Optical Drive 1: Blu-Ray Writer/Reader (Burn Blu-Ray discs and play them)
Optical Drive 2: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) (LightScribe Edition)
Internet Access: Killer Xeno Pro (Optimized for Online Gaming) Lag and Latency Reduction
Video Card: 3x CrossFire Triple (ATI Radeon HD 5870 1GB)
Add-on Card: !CLEARANCE HOT SELLER: BFG High-Performance Dedicated Ageia PhysX Card P1 128MB
Sound Card: Auzen X-Fi HomeTheater HD(HDMI v1.3a Compliant, 24p Compatible, Non-Downsampling, Native PCI Express Soundcard)+ The Auzen X-Fi Titanium I/O Drive
Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Triple SLI/CrossFire Video Cards & Chipset
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Red) (Up to 6 Fans)
Noise Reduction: Noise Suppression Package (Optimized Airflow & Fan Speeds with Noise Dampening Material)
Boost Processor: Stage 2: Overclock the processor between 4.0GHz to 4.2GHz (Requires H20 Cooling Upgrade)
Boost Video Card: Yes, Overclock the video card(s) as much as possible with complete stability
Boost Memory: Yes, Overclock memory frequency (Includes Memory Fan Kit Installed)
Boost OS: Yes, Disable and tweak all of the non-crucial services on the operating system
Windows OS: Dual boot Microsoft Windows 7 Ultimate (64-Bit Edition)*  Xp professional 32 bit.
Benchmarking: - No Thanks
Display:
Surge Shield: APC 1300VA Uninterruptible Backup Surge Conditioner (Recommended)
Speakers: Razer Mako THX Advanced Speaker System (2.1 System) (Includes Subwoofer) + Connetction to Denon Syntho via hdmi
Keyboard: Logitech Gaming G19
Mouse: Razer Mamba Laser Gaming Mouse con 5600 DPI e wireless connection 2,4 Ghz
philiporphillip View Drop Down
  Quote philiporphillip Quote  Post ReplyReply bullet Posted: 26 Nov 2009 at 3:19pm
wow, power hungry mobo and 3x 5870 .. you're future proof. i wouldn't get the add-on card because of the 5870. 6 gb of ram's enough .. you won't need 12 gb of ram unless you work with intensive 3d programs like 3ds max.
btw, why not pick the 5970? i think it's in stock.
Digital Storm
haf 922
i7-920 oc'd @ 3.6 ghz (1.28v)
evga x58 le edition sli
cooler master v8
6 gb ddr3 1600 mhz mushkin
evga nvidia geforce gtx 295 co-op edition
1000w corsair hx
  Quote philiporphillip Quote  Post ReplyReply bullet Posted: 26 Nov 2009 at 3:20pm
congrats on your marriage >,<
Digital Storm
haf 922
cooler master v8
1000w corsair hx
<8) slunK parade View Drop Down
  Quote <8) slunK parade Quote  Post ReplyReply bullet Posted: 26 Nov 2009 at 4:17pm
im guessing your using multiple monitors(i hope to god)
get rid of the Killer Xeno card, its useless
since your getting watercooling on everything why not go with a Corsair obsidian case?
  Quote Aceboy Quote  Post ReplyReply bullet Posted: 26 Nov 2009 at 5:47pm
After a long discussion with a teamwork friends,  and also after read some other configurations response in this forum from ds, i made a lot of change to my config.
Saving some money that may i use on the 2 & 3rd monitors. I have yet one monitor.
I also explain the use of this rig: most of time hard gaming, want to use also with my home theater that see a denon AVR-4310 + Samsung UE40B8000xw.
I need also a lot of space to archirve my documents e media.
So the new config sugested to me is this:
Motherboard: EVGA X58 Classified 3X SLI (Intel X58 Chipset) (Supports Triple SLI or CrossFire)
System Memory: Corsair XMS3 Dominator GT CMG6GX3M3A2000C8 6GB DDR3 3X2GB DDR3-2000 CL 8-8-8-24 Core i7 Memory KitPower Supply: 1000W Digital Storm Certified (Dual/Triple/Quad SLI Compatible) (Silent Edition Highly Recommended)
Hard Drive Set 1: Operating System: 4x (300GB Western Digital VelociRaptor (10K RPM) (16MB Cache) (Extreme Speed)
Hard Drive Set 2: Multimedia\Data: 1x (2TB Western Digital (7200 RPM) (64MB Cache) (SATA) (Extreme Speed WD2001FASS 2TB)
Hard Drive Set 3: Backup\Misc.: 1x (2TB Western Digital (7200 RPM) (64MB Cache) (SATA) (Extreme Speed WD2001FASS 2TB)
Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) (LightScribe Edition)
Optical Drive 2: Blu-Ray Writer/Reader (Burn Blu-Ray discs and play them)
Internet Access: Linksys Wireless-N 300Mbps (Supports 802.11n/g/b)
Video Card: 2x CrossFire Quad (ATI Radeon HD 5970 2GB) or
3x CrossFire Triple (ATI Radeon HD 5870 1GB)  the last one have my preference still now
Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Quad SLI/CrossFire Video Cards & Chipset
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Green) (Up to 6 Fans)
Enhancements: NVIDIA Enthusiast System Architecture (ESA) System (Install, Test, Optimize Computer)
Display: 3x
Samsung SyncMaster 2693HM
Edited by Aceboy - 26 Nov 2009 at 10:57pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Nov 2009 at 12:28am
time out, super overkill alert, wasting money with no performance gain alert.
what resolution does your monitor have?
you need a major overhaul on that config, some of the things you have picked won't even work together.
let me know the resolution of your monitor, and if you are going to buy 2 other monitors, then I have two more questions:
1. what is going to be resolution of those monitors.
2. when would you be purchasing those monitors.
let me know the answer to those 3 questions and lets fix that hot mess you got up there
Edited by DST4ME - 27 Nov 2009 at 4:01am
  Quote <8) slunK parade Quote  Post ReplyReply bullet Posted: 27 Nov 2009 at 3:52am
you really suck at spelling alert dst
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Nov 2009 at 4:02am
lol I don't know what is wrong with me tonight, too much turkey I think, I miss reading stuff and misspelling stuff all over the place
  Quote Aceboy Quote  Post ReplyReply bullet Posted: 27 Nov 2009 at 5:50pm
the monitor are a samsun syncmaster 25,5" and i use it normaly at 1920 to 1200 that is  the maximum of it's capability.
The 2 e 3 monitor will be bougth after had the new rig.
All the expenses come in next one or maximum two month,  before feb.
You said that some of the things you have picked won't even work together.i presume you tell about the ati graphics card e the physx card , i chose them becosue heard of a patch to overal the nvidia blocks.
satsunada View Drop Down
  Quote satsunada Quote  Post ReplyReply bullet Posted: 27 Nov 2009 at 6:59pm
Ya, don't trust those 3rd party patches on expensive hardware.
I'm pretty sure the incompatibility was the Physx card AND the hard drive striping setup. I could be wrong though.
If knowledge is power and power corrupts, then total knowledge corrupts totally.
Raif View Drop Down
  Quote Raif Quote  Post ReplyReply bullet Posted: 28 Nov 2009 at 3:16am
you have super over kill, what are you needs what games do you play?
1 case haf 932
2 processer 920 no point with 975 with the oc
3 6 gb is all u need 1600 mhz you wont really notice the difference between corsair and mushkin
4 way too much had space! what are your needs? also your raid set will make your velociraptors pointless. all that space = really really long defrang time
5 why do you need wireless on a desktop?
6 figure out what monitor set your getting and give us the res so we cqan give you better options of GPUs and not more then you need. also with ati's eyefinity 1 card can run 6 monitors
7 drop the physx not compatible and never trust 3rd party unless it is a reputable company that is 100% legit
8 change cooling to # of GPUs used
9 with that LC system you don't need the upgraded fans (noisy)
10 unless your video editing and other high end things you wont notice anything past 3.8 for gaming/. if your gaming stage 1
11 with the fans gone you wont really need the sound suppression. it will choke it
12 no need for GPU overclock
13 no need for os boost
14 no need for esa
14 windows 7 pro / ulitimate have xp mode no need for dual boot
Raif View Drop Down
  Quote Raif Quote  Post ReplyReply bullet Posted: 28 Nov 2009 at 3:18am
also just the fan kit on the memory
  Quote Aceboy Quote  Post ReplyReply bullet Posted: 28 Nov 2009 at 6:09am
1 case haf 932( i don't like it , if in the future i want to pass to a quad sli no possibility.)
2 processer 920 no point with 975 with the oc.
3 6 gb is all u need 1600 mhz you wont really notice the difference between corsair and mushkin (not during game but during some editing and other application, like 3dmax or ome other video editing work? the ram that i chise are in possession of some friends of mine  and alla are realy sutisfided of them, No t same direct knowlwdge of mushkin.)
4 way too much had space! what are your needs? also your raid set will make your velociraptors pointless. all that space = really really long defrang time( also i start think on a raid 0 for two vk300 to use Os, and a separate option for media & storage hd)
5 why do you need wireless on a desktop? (jthe working network is a different one from the personal line that i use, i cant take upstairs the intenet cables of the jobline.)
6 figure out what monitor set your getting and give us the res so we cqan give you better options of GPUs and not more then you need. also with ati's eyefinity 1 card can run 6 monitors (as i wrote before 1920:1200 is the bigger resolution that i can use now, but who can say the price of future monitor drops and make me capable of buy monitors that have better resolution, if i spend a lot i dont want a pc that need videocard upgrade after one year)
7 drop the physx not compatible and never trust 3rd party unless it is a reputable company that is 100% legit( like some said i need physx to some application like 3dmax, reading on forum seem near a ati direct patch in future, if wrong there no solution other than wait to see the Nvidia Fermi and drop the eyeinfinity, in this case no 2 e 3 monitor  but probably a 30" monitor with better resolution of 1920 :1200p)
8 change cooling to # of GPUs used ( my knowledge of english is poor sorry, i dont undertand the option of lc realy well , probably wrong choice no dupt of it hope dsteam chose the rigth one)
9 with that LC system you don't need the upgraded fans (noisy) ( i dont know if some fanse remand in a lc system if remain i want it upgraded red neon)
10 unless your video editing and other high end things you wont notice anything past 3.8 for gaming/. if your gaming stage 1 ( i use some video editor )
11 with the fans gone you wont really need the sound suppression. it will choke it ( like before don't know if some fans remain  if not i drop sound suppression)
12 no need for GPU overclock ( if it's stable oc like ds working  why not have some fre oc now that can make difference in future?)
13 no need for os boost ( just a choice to have  a os starting boosted , never make me unable to start other os backworks after, more work to boost after normal starting))
14 no need for esa( understand, thank)
14 windows 7 pro / ulitimate have xp mode no need for dual boot ( need a dual boot with xp32 so i can use old 32 bit program that dont run on 64 bit os.)
Thanks for a cler list of iusse Raif.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Nov 2009 at 6:17am
Processor: Intel Core i7 920 2.66GHz (Quad Core)
System Memory: 6GB DDR3 1600MHz Digital Storm Certified by mushkin enhanced (Highly Recommended) (Hand Tested)
Power Supply: 1000W Corsair HX (Dual/Triple/Quad SLI Compatible) (Silent Edition)
Hard Drive Set 1: Operating System: 1x (256GB Solid State (By: Corsair) (Model: CMFSSD-256D1)
Set 1 Raid Options: - Not Available
Hard Drive Set 2: Multimedia\Data: 1x 1TB seagate
Hard Drive Set 3: Backup\Misc.: 1x 1TB seagate
Video Card: 1 x 5970
Add-on Card: na
Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & one Video Cards
Chassis Airflow: no
Enhancements: na
Noise Reduction: na
Boost Processor: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz
Boost Video Card: no
Boost Memory: Memory Fan Kit only
Boost OS: no
Windows OS: Dual boot Microsoft Windows 7 pro (64-Bit Edition)
Display: 3xSamsung SyncMaster 2693HM
its needs to look more like this
Edited by DST4ME - 28 Nov 2009 at 6:18am
Raif View Drop Down
  Quote Raif Quote  Post ReplyReply bullet Posted: 28 Nov 2009 at 11:44am
DST4ME's build is very nice and he hit the nail on the head. also he saved you a ton of money. currently the 5970 is the best card out. it will be able to handle 6x of the monitors you chose.
Liquid cooling: pumps, resevoirs, tube ect. it majorly reduces your computer's hardware temperature, much more then then air cooling. the stock fans will still be there as well. also liquid cooling is non conductive (no worries about frying your hardware). it is also much quieter then fans. when you are doing intense gaming or your video editing the greater the demand on the machine the higher your temperature goes. the liquid cools it off and keeps it cool for longer under load. under special instructions ask for a extra bottle of fluid. i asked sarah from DS she said ti was $35, you will need to top the liquid cooling system off every once in a blue moon
if your gonna go quad i am not sure about your motherboard you may need the 4x sli ask DST he will know for sure.
GPU= Graphics card
LC= Liquid cooling
Raif View Drop Down
  Quote Raif Quote  Post ReplyReply bullet Posted: 28 Nov 2009 at 11:45am
anytime we are all here to help one another, don't hesitate to ask anything we like it lol.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Nov 2009 at 12:41pm
no he needs the 3x sli I gave him, 2 x 5970 is quad.
Raif View Drop Down
  Quote Raif Quote  Post ReplyReply bullet Posted: 28 Nov 2009 at 6:07pm
doesn't the 5970 take 2 slots? if so then wouldn't he need a 4x sli motherboard if he plans to upgrade in the future
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Nov 2009 at 7:19am
all gtx 2xx cards and ati 58xx cards take 2 pci slots.
the classified and 3x sli mobo are designed for tri sli, the classified can do tri sli and 2 other cards too.
I think you are mistaking taken up 2 pci slots with using 2 pci slots.
Raif View Drop Down
  Quote Raif Quote  Post ReplyReply bullet Posted: 30 Nov 2009 at 2:15am
so it using 2 slots but not taking them... go to know i was curious about that my self
red259 View Drop Down
  Quote red259 Quote  Post ReplyReply bullet Posted: 30 Nov 2009 at 3:09am
What does the OS boost do exactly? What are they disabling/tweaking?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 30 Nov 2009 at 11:11am
OS tweak, is nothing but some services disabled that you might not use, you will see no performance gain from it.
Raif View Drop Down
  Quote Raif Quote  Post ReplyReply bullet Posted: 30 Nov 2009 at 10:39pm
personally i would never mess around with the OS you can really screw some thigns up like that.
This page was generated in 0.1523438 seconds.
