Want a great gaming computer, need some help
Post Date: 2014-04-23
DR.SOLARVERSE View Drop Down
  Quote DR.SOLARVERSE Quote  Post ReplyReply bullet Topic: Want a great gaming computer, need some help
    Posted: 23 Apr 2014 at 11:29am
5000<
Great for gaming, high fps
gaming, casual internet
None really
Saved Ticket #: [Please Type Here]
This is what i came up with using the Bolt II Configurator, is it good for gaming?Specifications:
Chassis Model: Special Deal Hot Seller - Pre-built Digital Storm Bolt II
Exterior Finish: Exotic Paint Finish - Sterling Silver - Matte Finish <br><strong></strong>
Trim Accents: - No Thanks
Processor: Intel Core i7 4770K 3.50 GHz (Unlocked CPU) (Quad Core)
Motherboard: ASUS MAXIMUS VI IMPACT (Intel Z87 Chipset) (Mini-ITX) (SupremeFX Impact, Sonic Radar) <br><strong></strong>
System Memory: 16GB DDR3 1866MHz Corsair Dominator Platinum DHX (Extreme-Performance) <br><strong></strong>
Power Supply: 700W Digital Storm Bolt II Edition (Backordered ETA Early May) <br><strong></strong>
Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 8x / CD-Writer 8x) (Slim Slot Loading Edition)
Storage Set 1: 1x SSD (1TB Samsung 840 EVO) <br><strong></strong>
Storage Set 2: 1x Storage (2TB Western Digital - Enterprise Edition) <br><strong></strong>
Storage Set 3: - No Thanks
RAID Config: - No Thanks
RAID Card: - No Thanks
Graphics Card(s): 1x NVIDIA GeForce GTX 780 Ti 3GB (EVGA Superclocked ACX Cooler Edition) <br><strong></strong>
HPC Processor: - No Thanks
Extreme Cooling: 240mm Radiator Liquid CPU Cooler (Extreme-Performance Edition)
Chassis Fans: High Static Pressure - Corsair Air Series SP120 Fans (2x 120mm)
Internal Lighting: Front Panel + Internal Chassis (RGB LED Lighting System)
Airflow Control: Digital Storm Thermal Management Control Board & Software
Display: Asus 24 inch VG248QE Series (144Hz Refresh Rate) (Black) (1ms Response Time) (LED Backlight) <br><strong></strong>
Speakers: Corsair Vengeance 2100 Wireless Dolby 7.1 Gaming Headset <br><strong></strong>
Keyboard: Corsair Vengeance K70 (Mechanical Gaming Keyboard) (Black/Metal Finish) <br><strong></strong>
Mouse: Corsair Vengeance M65 White (Laser 8200 dpi) (FPS Gaming Mouse) <br><strong></strong>
Portable Gaming: - No Thanks
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 Apr 2014 at 12:06pm
Hi Dr.SOLARVERSE...  Welcome to the forums.
The Bolt 2 with the 780ti and i7-4770k is an excellent gaming rig.  Can't do any better for a single card system.   For gaming, the 4670k also works just as good for less money, but the i7 does give longevity and helps with other tasks.
The Bolt can't sli, 2x video cards, but if that's not an issue, and for most it isn't, then the  Bolt rocks.   Lots of power in a small package.
Good luck and stay in touch. Big%20Smile
  Quote DR.SOLARVERSE Quote  Post ReplyReply bullet Posted: 23 Apr 2014 at 12:20pm
Thank you so much, puts my mind at ease, and doubling up my video cards would just be if i want two monitors right?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 Apr 2014 at 1:08pm
Right. Sli would be for multi monitor gaming or high resolution monitor like a 27" at 2560x 1440 resolution and keeping settings on as high as possible.
For your 24" monitor this rig will play Great for a long time.
