Voltage always stays same??
Post Date: 2014-10-22
robertden View Drop Down
  Quote robertden Quote  Post ReplyReply bullet Topic: Voltage always stays same??
    Posted: 22 Oct 2014 at 9:25am
I have OC my 4770k with Z87 Gryphon Mobo to 4.3 and left the core voltage on auto. Why does the voltage read 1.223 before, during, and after a stress test? Isn't it supposed to ramp up and down with the amount of load?(Just a noob)
Meller View Drop Down
  Quote Meller Quote  Post ReplyReply bullet Posted: 22 Oct 2014 at 11:10am
Never overclocked on that motherboard, nor do I have any experience surrounding that Gryphon lines.
Why would you leave it on Auto? Honestly, and not trying to sound mean here, but that is a horrible idea. If you lack experience on overclocking, you should have looked up tutorials on how to do it, a long with some decent recommended starting points.
All my years of overclocking, I've never once left it on Auto.
If it's staying at 1.223 volts, that's most likely the motherboard keeping it there. That could be good or bad. But I'm guessing not so good.
Ryzen 9 5950X
Gigabyte X570 Aorus Xtreme
128GB DDR4 3600mhz
Samsung 980 Pro 512GB m.2
Samsung 960 PRO 2TB m.2 x2
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 Oct 2014 at 11:30am
I don't do oc'ing but could this be the Speedstep under CPU Power management isn't enabled in AI Tweaker?
  Quote Meller Quote  Post ReplyReply bullet Posted: 22 Oct 2014 at 1:12pm
The only way that would be applicable here bprat is if he set his min and max power % to 100%. But then that means his oc would stay at 4.3ghz at all times. There's a tid bit of info we're missing here in terms of how he did his over clock, what all was changed, etc to even begin to figure out what the issue is.
Ryzen 9 5950X
128GB DDR4 3600mhz
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 Oct 2014 at 1:24pm
Got it. With vcore feeding the clock, I'd think it would be the same, but more does go into overclocking.
Thanks.
  Quote robertden Quote  Post ReplyReply bullet Posted: 22 Oct 2014 at 4:55pm
Thanks for the feedback all. Like I said I'm a noob at this. One other question. I've had this small overclock setting([email protected]) for at least a year and only had one BSOD but the debugging info points to a CPU hardware problem and DS support said I could ignore it since it's only one BSOD in a year or raise the Vcore by.05.What's the consensus here-leave well enough alone or raise the voltage?? Thanks again.
And one other thing -my BIOS has an "Auto" mode and an "Adaptive" mode under core voltage. What's the difference??
Edited by robertden - 22 Oct 2014 at 5:52pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 Oct 2014 at 8:32am
I wouldn't worry about one BSOD in a year.  I've had more than that just uninstalling software.    Hahaha       You could try to tweak the voltage, wouldn't hurt but that's up to you.
  Quote robertden Quote  Post ReplyReply bullet Posted: 23 Oct 2014 at 9:23am
I was wrong.I have it on adaptive mode and have the voltage set at 1.223 but in a Intel benchmark the voltage peaked at 1.31 and reached 44 GHz OC.Is auto mode what Asus deems best and adaptive mode is what I set as range?
Edited by robertden - 23 Oct 2014 at 3:22pm
This page was generated in 4.492188E-02 seconds.
