Video Card QuestionPost Date: 2014-10-17 |
Caymus
Groupie Joined: 20 Dec 2008 Online Status: Offline Posts: 287 |
Topic: Video Card Question Posted: 17 Oct 2014 at 11:11am |
Thinking of swapping out the GTX 580's (SLI) for a GTX 980 on an aging but still strong Digital Storm rig. Any bottle necks? Will I receive full benefit from the 980?
*specs below* Intel i7 Extreme 965 ( clocked @ 3.8 ) MB: Rampage 3 extreme Ram: 12 gb ASUS GTX 580's SLI Thanks |
Quote Reply Posted: 17 Oct 2014 at 12:06pm |
I don't see any problem. The 965 clocked to 3.8 should be fine. Still a good chip. I can't say no bottleneck at all with every situation, but certainly not enough to warrant a new setup.
Your mobo's Pciex16 slots are version 2.0, Pcie 2.0, and the new cards are 3.0 , but they are backward compatible with little or no performance loss, especially with a single card. Bandwidth is fine. You'll see better frames, a lot less wattage used and lower heat, and quieter. Win, Win, Win. |
Caymus
Quote Reply Posted: 17 Oct 2014 at 12:58pm |
Thank you.
Quote Reply Posted: 17 Oct 2014 at 5:25pm |
Your biggest bottle neck at this point will either be your HDD's assuming you're not using SSD's and your cpu. Though don't get caught up on "biggest". Neither is extreme. Just aged. The instructions for an old first gen i7 are starting to get dated, but you should be good and see no issues at all.
