Velox buildPost Date: 2014-12-01 |
robjmag89
Newbie Joined: 01 Dec 2014 Online Status: Offline Posts: 11 |
Topic: Velox build Posted: 01 Dec 2014 at 6:33am |
I just ordered my Velox setup a few weeks ago and I am waiting on a back ordered part now. I have some extra credit on my account to spend on upgrades. What I am wondering is if my Power supply is going to be sufficient enough for this build. Here is the build. Thanks all!
Chassis Model: Special Deal Hot Seller - Digital Storm Velox
Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 4790K 4.0 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) Motherboard: ASUS SABERTOOTH Z97 MARK2 (Intel Z97 Chipset) (Military-Grade TUF Components) System Memory: 16GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 750W Corsair CX750M Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x SSD (250GB Samsung 840 EVO) Storage Set 2: 1x Storage (1TB Seagate) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 970 4GB (EVGA ACX Cooler Edition) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Corsair H110 280mm Radiator Liquid CPU Cooler (Extreme-Performance Edition) H20 Tube Color: - Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Upgrade All Fans to Corsair Airflow Performance Edition (Up to 6 Fans) Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks CPU Boost: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires High-End Motherboard Selection) Graphics Boost: Yes, Overclock the video card(s) as much as possible with complete stability Memory Boost: - No Thanks, Please do not overclock my memory OS Boost: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 8.1 (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks NVIDIA SHIELD: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) |
Quote Reply Posted: 01 Dec 2014 at 7:06am |
Hi robjmag89... Welcome to the forums and Congrats on the order.
Real nice rig. The 750watt is fine for the sli gtx 970's. If you can , the EVGA 850watt SuperNova for another $56 does give you more headroom, although you are good, but also gives you a Gold vs Bronze efficiency rating, a 10 year vs 3 year warranty and a fully modular vs semi modular unit. The semi modular cabling means the motherboard cables are hardwired, the others plug-in. The fully modular of the 850w SuperNova has all the cables plug-in for easier replacement if ever needed. The 750 watt is very good, the 850 watt is better and has some nice features for the extra $$. Hope this helps. |
robjmag89
Quote Reply Posted: 01 Dec 2014 at 7:18am |
Thanks alot and Im hoping Ill be able to switch it out before it ships!
Quote Reply Posted: 01 Dec 2014 at 7:25am |
You're welcome. If the case is still on back order, then it shouldn't be an issue. They can test individual components but can't get far without the case to put it all together. Call or email the change as soon as you can.
Stay in touch. |
