VanquishII Level 2 concernsPost Date: 2014-03-13 |
Lumiair
Newbie Joined: 13 Mar 2014 Online Status: Offline Posts: 2 |
Topic: VanquishII Level 2 concerns Posted: 13 Mar 2014 at 9:47am |
~$950 part of the budget will have to go towards a monitor. Expectations: Being able to play WoW, Diablo, LoL on high-ultra. Usage: Gaming/casual web browsing Special Needs: Converting from an iMac so I'm used to an all in one* I'm aware it doesn't come with wifi capabilities but unfortunately I don't have any other option with my current setup. Would I be hindering the system much in way of performance to just get a USB adaptor or would it be fairly simple to install one myself? (Not too experienced in this department) Another thing I'm not certain on is does it have Bluetooth capabilities? I'd really prefer to keep the keyboard I currently use. Anything else I should be concerned about that I'm overlooking? Thank you very much for your time, Clint |
Quote Reply Posted: 13 Mar 2014 at 10:07am |
USB 2.0 has an effective throughput of upto 280Mbps, which is faster then most internet connections in the US. So no, you shouldn't have an issue.
As far as Bluetooth, it does not have internal an internal Bluetooth radio. But, you can do this with a USB device as well. There are USB WiFi + Bluetooth devices available. We could better comment on your ability to run the games that you ask about if we knew the resolution of the monitor you intend to run. I honestly don't play any of the games you mention, but I am doubtful that the Vanquish II L2 will be able to hit Ultra quality on them. It is a lower mid-range system. |
Lumiair
Quote Reply Posted: 13 Mar 2014 at 10:42am |
Thank you, that's good to know! And I can certainly live without ultra. I'd prefer to run at 2560 x 1440 as I'm used to that, but with my budget most likely 1920x1200. |
Counsel
Quote Reply Posted: 14 Mar 2014 at 1:31pm |
Good news - TechPowerUp benchmarked the GTX 750 Ti on both Diablo III and World of Warcraft, so you can get a sense of what the Vanquish 2 will pull. Diablo III http://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_750_Ti/16.html Judging by the 1600P numbers, you'll be able to max all settings and still average 60fps @ 1440P. At 1080P, you're looking at 87fps. World of Warcraft Again, judging by the numbers 1600P numbers, you'll hit somewhere around 50fps @ 1440P. At 1080P, you're looking at 57fps. That's on Ultra. Keep in mind that you probably won't hit those numbers in raids and other crowd situations, as those tend to be limited by your CPU and not your GPU. The i3 4330 is a respectable CPU, so you shouldn't end up falling in the Ironforge Trench, but I wouldn't recommend trying to PvP in major cities. TechPowerUp's Test Bench http://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_750_Ti/6.html |
