Vanquish L3 v L4?Post Date: 2015-03-04 |
nayots
Newbie Joined: 22 Feb 2015 Online Status: Offline Posts: 20 |
Topic: Vanquish L3 v L4? Posted: 04 Mar 2015 at 5:39pm |
How much stronger is the L4 vs the L3, deciding between one of them. Can't tell if it's worth the money
Quote Reply Posted: 04 Mar 2015 at 5:46pm |
For gaming the lvl 4 is roughly 40% better frames per second with its stronger video card. Look at the Benchmark section in the Vanquish section for some comparisons.
Lvl 4 also has a SSD , better cpu cooler, an overclocked cpu and a motherboard able to sli. Hope this helps. |
Quote Reply Posted: 05 Mar 2015 at 9:29am |
HI nayots,
bprat22 is right on target. The level 4 is well worth the extra money if you can swing it. That doesn't mean the level 3 is not a good computer, just lower performance. The level 3 is still a good buy. If you are not cost limited then go for the level 4. Frank |
