Vanquish II QuestionsPost Date: 2014-07-28 |
Blay_Zett
Newbie Joined: 01 Jul 2014 Online Status: Offline Posts: 46 |
Topic: Vanquish II Questions Posted: 28 Jul 2014 at 4:08pm |
DISCLAIMER: I know it probably can, but I like to be thurough.
The games I commonly play include (but are not limited to): Euro Truck Simulator 2 (Vanilla) Garry's Mod (Lots of Addons) Minecraft (Lightly Modded) And most likely others if/when I get the computer, such as: DayZ Minecraft (Heavily Modded) Fallout: New Vegas (Vanilla) Rage (Vanilla) I also intend to try programming in Java (and other languages later), and maybe do some recording and editing. I don't know for sure what computer or level I'll get (if any), but before asking I'll assume it will be a Vanquish II Level 4. If it's not too much to ask, how will the different Vanquish II levels do for each of those things? (My current monitor is 1366x768. Possible upgrade in the future.) |
"I will annihilate you with my awesome." -Nerd³
Quote Reply Posted: 28 Jul 2014 at 5:14pm |
At 1366x768, even the Level 2 will play most of the games maxed out with tons of mods.
However, if you plan on going to 1080p in the near future, the Lv.4 will guarantee the ability to play max or near-max settings at 1080p. |
Blay_Zett
Quote Reply Posted: 28 Jul 2014 at 5:22pm |
Thanks!
Another question... I'm going to be using Eclipse, a program that writes, compiles and runs Java. Will it run that well? My family thinks I'm a computer expert, but I'm not. Edited by Blay_Zett - 28 Jul 2014 at 5:48pm |
Quote Reply Posted: 29 Jul 2014 at 3:38am |
@Blay_Zett ... while I can't speak to programming with Eclipse, I will tell you that the Vanquish II Ultimate will run Skyrim and Fallout New Vegas VERY heavily modded (100+ mods on Skyrim and 50+ on FO:NV).
The GTX 770 doesn't even break a sweat on this machine. Granted, I'm not running really high resolutions or multiple monitors, to really try to stress it. I just think, for today's games on normal setups, the Vanquish II Ultimate is a really, really good machine. Just my 2¢... |
Blay_Zett
Quote Reply Posted: 29 Jul 2014 at 5:48am |
Thanks again. Since I'm already used to running at absolute minimum settings (at 1280x720), it seems I won't have any issues should something not run at max.
