Vanquish II motherboardPost Date: 2014-07-18 |
jdaddle
Newbie Joined: 18 Jul 2014 Online Status: Offline Posts: 11 |
Topic: Vanquish II motherboard Posted: 18 Jul 2014 at 8:22pm |
Is the Asus H81 motherboard that the Vanquish comes with PCI express 3.0? and what model is it?
Quote Reply Posted: 19 Jul 2014 at 5:08am |
Good questions. I think since Pciex 3.0 isn't mentioned, that it's 2.0. But, for its single graphic card limit, it really doesn't matter. No card today will see much of a difference and they are all 2.0 backward compatible. For the gtx 770, absolutely no difference.
What model, D or E, depends what they have at the time. Edited by bprat22 - 19 Jul 2014 at 5:09am |
Quote Reply Posted: 19 Jul 2014 at 7:13am |
While I don't seen anything on the Asus's specs page for that motherboard, I believe that the PCIe 16x controller is on the processor which should support 3.0. I am not sure if Asus has done the work on the motherboard to comply with the 3.0 spec, though.
