FBPost Date: 2014-09-12 |
FattyBluntface
Newbie Joined: 10 Apr 2014 Online Status: Offline Posts: 13 |
Topic: FB Posted: 12 Sep 2014 at 12:35am |
FB
Edited by FattyBluntface - 25 Feb 2016 at 11:53pm |
Quote Reply Posted: 12 Sep 2014 at 3:11am |
The Vanquish II have the H81m-d mobo which has a Pciex16 slot for your graphics card and 2x pciex1 slots. The graphics card fills the x16 and overlaps one of the x1 slots, leaving you an open pciex1 slot. Compatability and speed you'd have to check.
It does have 2x Sata 3 and 2x Sata 6 ports, two of them open with your HDD and optical drive. It might be cheaper and faster speeds to use a Sata vs pciex1 slot SSD if one is open. Hope this helps. |
FattyBluntface
Quote Reply Posted: 13 Sep 2014 at 9:16pm |
FB
Quote Reply Posted: 14 Sep 2014 at 3:27am |
If you mean, is the motherboard and number of slots good, then if it meets your needs and within the budget, then it's fine. It is an entry level motherboard but for this price range it works. Most buyers want a single graphics card and one or two drives and this fits.
