VPost Date: 2014-08-29 |
FattyBluntface
Newbie Joined: 10 Apr 2014 Online Status: Offline Posts: 13 |
Topic: V Posted: 29 Aug 2014 at 9:49pm |
I
Edited by FattyBluntface - 25 Feb 2016 at 11:52pm |
Moderator Group Just a dude trying to keep the spam away Joined: 23 Jan 2014 Online Status: Online Posts: 9462 |
Quote Reply Posted: 30 Aug 2014 at 12:24am |
Yes, that will be fine. The Vanquish II case is not meshed on the sides, only top, front and rear. (And the bottom PSU Filter.)
As you can see, when you take the side panels off, they are solid and don't need any room for venting.
Front and rear and the most important areas for clearance, Clarence. Then top and bottom and finally sides.
Hope this info helps.
Cheers!
