Vanquish II Level 4 questionsPost Date: 2014-08-09 |
Rockcem
Newbie Joined: 09 Aug 2014 Online Status: Offline Posts: 86 |
Topic: Vanquish II Level 4 questions Posted: 09 Aug 2014 at 11:33am |
Hello! I am set on buying a Digital storm Vanquish II computer. I just have a couple questions, Should I wait an extra 2 weeks to buy an Level 4 or just buy level 3, Is a level 4 really worth it?
Also I bought an Asus VG248QE and I was wondering if Vanquish Level 3 or 4 could take advantage of the 144Hz? |
Quote Reply Posted: 09 Aug 2014 at 2:34pm |
That honestly depends on if you can stand to wait. If you really need something now, you should do it now. Here is a list of benchmarks comparing the two GPUs: http://www.anandtech.com/bench/product/1038?vs=1037.
The frame rate will vary depending on settings you use and what games you play. The benchmarks I linked to above should give you a pretty good idea of what kind of frame rates to expect from different types of games. |
Rockcem
Quote Reply Posted: 09 Aug 2014 at 4:01pm |
Quote Reply Posted: 09 Aug 2014 at 9:44pm |
Yes.
Yes and yes.
The 3 is a very very good budget machine. The 4 is just a bit better, imho.
The SSD, cooler and GTX770 are definitely worth the higher cost.
I store all my system files and games on the SSD, while large data files (like music and movies) are holding in the HDD.
I don't understand the differentiation between wired and wifi. All Vanquish models need the wifi dongle. This should make no difference in cooling or number of drives.
Rockcem
Quote Reply Posted: 09 Aug 2014 at 9:48pm |
Okay! Awesome! You sir are the reason I will buy a L4 instead of a L3 :p |
