Vanquish II level 4 arrivedPost Date: 2015-03-18 |
Watata
Newbie Joined: 25 Feb 2015 Online Status: Offline Posts: 12 |
Topic: Vanquish II level 4 arrived Posted: 18 Mar 2015 at 9:39pm |
It's all hooked up and everything arrived immaculately the only concern I have is this fan mate, do I have to install it? I hadn't put it on yet and my PC was feeling a little warm today. I have no idea what the Fan mate thing even does or is :S
Pacesetter
Quote Reply Posted: 18 Mar 2015 at 11:36pm |
Is this what we are referencing?
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118217 If so it is a controller for fan speeds. Look over the reviews and questions on the above link and it will answer a lot. You can monitor temps and voltages with http://www.cpuid.com/softwares/hwmonitor.html This will tell you if it is indeed running hot. If it is cool then the option is yours and may be based on COOL IT MORE >'-) or control fan noise for a quiet environment. |
Quote Reply Posted: 19 Mar 2015 at 4:59pm |
You don't really need to worry about using that. Especially for the VANQUISH line.
Clay
Quote Reply Posted: 19 Mar 2015 at 7:58pm |
Pics?
I7 13700KF 5.4hz
Quote Reply Posted: 20 Mar 2015 at 3:36pm |
Let's see some pics!
