Vanquish II Core i3 QuestionPost Date: 2014-08-18 |
FattyBluntface
Newbie Joined: 10 Apr 2014 Online Status: Offline Posts: 13 |
Topic: Vanquish II Core i3 Question Posted: 18 Aug 2014 at 3:16pm |
Is the core i3 in Vanquish level 2 still good enough for modern games, and is it going to be considered outdated any time soon?
Quote Reply Posted: 19 Aug 2014 at 3:46am |
Hi FattyBluntface.... The basic answer is to get what your budget allows. If the level 2 with its gtx 750ti and dual care i3 is it then you'll get decent entry level gaming, with settings on medium to high on a 1920x1080 monitor.
If you can afford a little more, the level 3 with gtx 760 and quad core cpu will give you a healthy 40% increase in gaming. Quad core gaming is here now and will only get stronger but dual core is still good for most games. Dual core will restrict you with multi-tasking, streaming and populated MMO plus games like Crysis, BF4. But, teamed with the gtx 750s, the dual core is a good match. Can't just look at the cpu, but the whole package. Under the Configuration Discussion section is Vanquish Benchmarks that show the comparisons. Hope this helps and good luck. |
