Vanquish GPU question
Post Date: 2014-01-11
Page  12>
bowlofsoup View Drop Down
  Quote bowlofsoup Quote  Post ReplyReply bullet Topic: Vanquish GPU question
    Posted: 11 Jan 2014 at 6:11pm
So, I'm thinking about picking up the level 3 vanquish, and I had a quick question. From what I understand, DS uses a reference card in the Vanquish. How are the temperatures of the GTX 760 under stress? How's the airflow in the case? I'm just not sure what to expect since I'm moving away from using laptops, and mine ran ridiculously hot all of the time.
Edited by bowlofsoup - 11 Jan 2014 at 6:12pm
Nav View Drop Down
Moderator Group
Moderator Group
Digital Storm Employee
  Quote Nav Quote  Post ReplyReply bullet Posted: 11 Jan 2014 at 6:42pm
We use both reference and non-reference cards depending on what we have in stock. Temperatures can vary depending on ambient temps and the version of the card used. Airflow is not an issue it will definitely run cooler than a laptop.
  Quote bowlofsoup Quote  Post ReplyReply bullet Posted: 11 Jan 2014 at 6:55pm
Gotcha. My laptop had a 660m in it, and it was consistently north of 95c. Had it repasted, and it still ran at those temps. Thanks for the reply
Edited by bowlofsoup - 11 Jan 2014 at 6:56pm
Nav View Drop Down
Moderator Group
Moderator Group
  Quote Nav Quote  Post ReplyReply bullet Posted: 11 Jan 2014 at 7:32pm
No worries, the Vanquish will definitely run cooler than your laptop!
Edited by Nav - 11 Jan 2014 at 7:32pm
Tidgxor View Drop Down
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 11 Jan 2014 at 8:06pm
Yeah, don't worry, the Vanquish will be far, far cooler than your laptop. Possibly even more quiet. Some laptops can be screamers.
  Quote bowlofsoup Quote  Post ReplyReply bullet Posted: 13 Jan 2014 at 12:15am
Well, I'm sold.
  Quote bowlofsoup Quote  Post ReplyReply bullet Posted: 16 Jan 2014 at 8:46pm
Probably going to order this tomorrow, and just wanted to ask one more question. Can anyone recommend a quiet fan that I can add to my case? I want to add one on the side panel right over the gpu. I've been a laptop guy for too long, still paranoid. Haha On the other hand, would this have a negative effect on the airflow in the case?
Edited by bowlofsoup - 16 Jan 2014 at 11:15pm
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 17 Jan 2014 at 3:20am
I have mounted 2 Nexus d12sl fans to a side panel and highly recommend them. Quiet and easy to mount and hookup to either mobo or to psu peripheral power plug in the harness.
Corsair sp120 Quiet series have great reviews.
Lots to pick from.
I suggest downloading the free HWMONITOR and run it while stressing the rig. It checks cpu cores and gpu temps.   If all stays in the 60s and 70s then your good to go.
Good luck.
  Quote bowlofsoup Quote  Post ReplyReply bullet Posted: 17 Jan 2014 at 5:27am
Ok, thanks for the recs man.
manowar09 View Drop Down
  Quote manowar09 Quote  Post ReplyReply bullet Posted: 17 Jan 2014 at 8:41am
I just got a vanquish 3 with a standard referenced 760. It stays cool while gaming. I've been monitoring the temps for the cpu and gpu and all been great so far. I've mostly seen the gpu cap at around 75 and the cpu is about 48ish. Also with the gtx 760, I have the EVGA card and you download there presicion tool for the video card. You can even set a temperature target, such at 70 or something it will throttle back the card slightly if needed to keep it at that lower temp.
But overall you don't have to worry about cooling at all the way DS gives you the comp and you can probably make it better if you add in extra fans.
  Quote bowlofsoup Quote  Post ReplyReply bullet Posted: 17 Jan 2014 at 6:20pm
That's good to know. Thanks for the info. Also, did the assassin's creed come as a steam download code?
  Quote bowlofsoup Quote  Post ReplyReply bullet Posted: 17 Jan 2014 at 9:18pm
Ordered the level 3. Can't wait. AwesomeJust curious, but how do I get the assassin's creed code?
Edited by bowlofsoup - 17 Jan 2014 at 9:21pm
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 17 Jan 2014 at 9:33pm
The Assassin's Creed code is for Uplay, it should be on a little piece of paper with your owner's binder.
  Quote bowlofsoup Quote  Post ReplyReply bullet Posted: 17 Jan 2014 at 10:30pm
Gotcha. Thanks for the help.
  Quote bowlofsoup Quote  Post ReplyReply bullet Posted: 27 Jan 2014 at 4:58pm
So, my vanquish just came in today. I was just wondering if someone would be able to help me out with something. I bought an asus monitor that has built in speakers, so I set it as the default device to run sound through. Now, whenever I plug in a pair of headphones, the sound still come out of the speakers. Does anyone have a fix for this? Sorry if this is a stupid question, but I've been exclusively using laptops for about 6 years now, so I never really had monitor compatibility issues to deal with.
Edited by bowlofsoup - 27 Jan 2014 at 4:59pm
  Quote bowlofsoup Quote  Post ReplyReply bullet Posted: 27 Jan 2014 at 6:23pm
Never mind guys, figured it out. In other new, I'm happy to see that my vanquish came with a modular psu instead of the standard one that it was advertised with.
fstcvc View Drop Down
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 27 Jan 2014 at 10:48pm
HailStorm II
i7 4770K @ 4.5GHz
Asus Maximus VI Extreme
  Quote bowlofsoup Quote  Post ReplyReply bullet Posted: 29 Jan 2014 at 4:41pm
I know this is the wrong place, but I didn't think I should make a new thread for this. I just attempted to use my redemption codes for assassin's creed black flag and splinter cell, and they aren't working at all. I 'll add the promo code, but the subtotal won't go down. Anyone have any idea why this is happening?I'll try again in a bit, this always happens to me with uplay.
Edited by bowlofsoup - 29 Jan 2014 at 4:45pm
  Quote Alex Quote  Post ReplyReply bullet Posted: 29 Jan 2014 at 5:30pm
Contact us and we'll help you out.
  Quote bowlofsoup Quote  Post ReplyReply bullet Posted: 29 Jan 2014 at 5:53pm
I'm going to wait it out. I've had the uplay site do this to me before, and it has always worked out fine.
  Quote bowlofsoup Quote  Post ReplyReply bullet Posted: 29 Jan 2014 at 6:12pm
Just tried the code again, and this time I received one for splinter cell too. Both of them worked with uplay. Never fails. Can't wait to actually put in some more time actually playing on this guy, I'm basically just transferring my steam account over and downloading the free games. After some actual time with it, I'll put up a review. Pictures are good to go.
  Quote bowlofsoup Quote  Post ReplyReply bullet Posted: 09 Feb 2014 at 8:24am
So, I've been really enjoying my Vanquish so far, but I just had a small question. My rear outtake fan wobbles a bit when it spins, and I was wondering if this is anything I need to worry about? The frame of the fan itself is solid, but the blade is the part that is wobbling. Is there a way to fix this?
Edited by bowlofsoup - 09 Feb 2014 at 8:25am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 09 Feb 2014 at 9:00am
If the fan isn't making any noise, then its probably good to go.
You could try pressing it in the middle from front and back and see if it reseats and squares itself. It presses into the motor, usually.
But, you could also break it if not careful. I would try it myself, but up to you.
From the words of Dirty Harry, " Are you feeling lucky".
  Quote bowlofsoup Quote  Post ReplyReply bullet Posted: 09 Feb 2014 at 9:08am
Thanks for the help. I'll try it out when I get home.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 09 Feb 2014 at 11:18am
   If it works, let us know.
  Quote bowlofsoup Quote  Post ReplyReply bullet Posted: 11 Feb 2014 at 5:02am
Went to make the fix you suggested yesterday, but it turns out that the mold of the plastic is just slightly off. So, really it just looks like there's an issue where there isn't one.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 11 Feb 2014 at 7:45am
Thanks for the feedback.    Enjoy.
  Quote bowlofsoup Quote  Post ReplyReply bullet Posted: 15 Feb 2014 at 11:39am
So, just a quick update and questions about temps and stuff. Just curious if these number seem normal to everyone. The max numbers are after playing Far Cry 3 for about 10 minutes. The GPU usage was around 98% the entire time.
http://imgur.com/sewer6Y
Speaking of far cry 3, for some reason the recommended setting come up as ultra. Obviously, the 760 can't max this game out, and I was just wondering if someone with the same card could give me an idea of what the ideal settings would be. I'm playing at 1080p, and I would love to use some of the anti-aliasing to make the jungle look a bit less sharp around the edges.
Edited by bowlofsoup - 15 Feb 2014 at 11:52am
  Quote bowlofsoup Quote  Post ReplyReply bullet Posted: 15 Feb 2014 at 11:53am
Now that I think about, what's the best way to post images here?
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 15 Feb 2014 at 12:28pm
click on the full reply editor which is the button next to the ? thingy. Then go to Image Upload
Storm Trooper
i5 3570k
Ordered: 11-27-12
Stage 1: 11-29-12
Stage 2: 12-2-12
Stage 3: 12-2-12
Stage 4: 12-4-12
Stage 5: 12-4-12
Stage 6: 12-10-12
Stage 7: 12-12-12
Nav View Drop Down
Moderator Group
Moderator Group
  Quote Nav Quote  Post ReplyReply bullet Posted: 15 Feb 2014 at 12:36pm
Those temps are just where they should be.
  Quote bowlofsoup Quote  Post ReplyReply bullet Posted: 15 Feb 2014 at 12:50pm
Thanks everyone. Excited
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 15 Feb 2014 at 9:28pm
HailStorm II
i7 4770K @ 4.5GHz
  Quote manowar09 Quote  Post ReplyReply bullet Posted: 15 Feb 2014 at 10:45pm
Sometimes if you google something like "far cry 3 graphic settings" you can find a run down on what all the settings do and how much they impact performance.  I never played far cry 3 so I couldnt help you out with anything specific.
Sometimes its just one setting killing you.  For The Witcher 2 for example if you use ultra, it puts ubersampling on which requires some serious power.  But if you turn that off and leaving everything else on ultra, the game runs 60fps+ all the time.
  Quote bowlofsoup Quote  Post ReplyReply bullet Posted: 24 Feb 2014 at 6:58am
Ok, so I've been having a minor problem since yesterday. To start off, I had to tighten up my cpu cooler since it was vibrating and making a loud clicking noise. I've fixed that, and I've been having no problems with the noise. My issue, since I opened up the tower, is that when the computer boots up , there seems to be about a 20 second period between the windows load screen and the login screen where there is just a black screen. Just wondering if this is normal? This wasn't happening at all up until the day before, and I'm positive that I didn't damage the machine in any way when I went to fix the cooler.
This page was generated in 0.15625 seconds.
