Vanquish 2, setupPost Date: 2014-06-15 |
Pwned24
Newbie Joined: 15 Jun 2014 Online Status: Offline Posts: 1 |
Topic: Vanquish 2, setup Posted: 15 Jun 2014 at 1:26am |
Alright, I made up my mind that I will make Digital Storm the mother of my very first desktop ( gonna buy quite SOON). XD . Any help or tips on the setting up of the system will be much appreciated and I also won't be using an Ethernet cable and would like to know how to allow the desktop to connect to wifi . Many thanks guys
Quote Reply Posted: 15 Jun 2014 at 8:03am |
Welcome to the forums...
Vanquish II set up is very straight forward, when you get your rig, unpack it and carefully pull the foam cushion they pack inside. When you do, take a good look around in there and make sure everything is seated properly. You'll notice a LOT of space to move around, just be grounded when you start pushing cards into their slots.... Put the cover back on, most peripherals are plug and play, take the protective cover from the window and enjoy your new rig. As for wifi, just get a usb dongle from amazon, etc. There are lots of threads around here that can show you those. Good luck and enjoy. |
