tju76
Topic: Uv reactive Die or clear fluid Posted: 12 Jun 2012 at 8:29pm |
any disadvantages from adding some uv reactive dye into my cooling loop, i saw a post that said it can ruin the components, junk up the pumps? thanks guys
Err0xx
Posted: 12 Jun 2012 at 8:36pm |
I imagine it depends on the properties of the UV dye. Most is labeled as non-corrosive, etc. I've had UV reactive dye in a cooling loop on my current pc for 6 years. Never had a single issue with it, still running good.
tju76
Posted: 13 Jun 2012 at 11:42am |
could you reccomend me a brand? what do you use?
Asangard
Digital Storm Live Chat Rep.
Posted: 13 Jun 2012 at 7:05pm |
Hi tju76, I beleive DS still uses Feser One Cooling Fluid (clear) which is UV reactive. So you shouldn't need to add any thing to your cooling loop.
tju76
Posted: 13 Jun 2012 at 8:03pm |
no its clear liquid trust me lol, And the stage 6 LC are all the parts copper like rads blocks
Posted: 13 Jun 2012 at 9:38pm |
We use Feser One clear, which can be UV reactive with cold cathode UV lights (however it won't be super bright like UV green fluid).
Asangard
Posted: 14 Jun 2012 at 3:55am |
The Feser One Clear used by DS is UV reactive. You need a UV light source to make it glow. If you are looking for a colored fluid that is also UV reactive Feser makes a number of different colored fluids that are also UV reactive. Here is a link to their site: http://www.tfc-us.com/shop/You will still need a UV light source to lake them glow. I hope this helps.
Edited by Asangard - 14 Jun 2012 at 3:56am
tju76
Posted: 14 Jun 2012 at 4:55am |
Since the liquid is not just distilled water how often should I take everything out of the loop to clean it like the rads and blocks
surf71zx
Posted: 14 Jun 2012 at 8:11am |
tju76 on the Feser One cooling fluid bottle it says in BOLD HIGH LIGHTED letters, Do Not Mix with other liquids. Take it for what its worth from the manfacturer. There address is www.Feser-One.com.
tju76
Posted: 14 Jun 2012 at 11:00am |
yeah i am not mixing anything into the fesser i thought it was just clear liquid not uv reactive i am buying some more UV CCFL lights todays, how often should i clean all of the components in the loop
Err0xx
Posted: 14 Jun 2012 at 6:08pm |
To my knowledge, not very often. The Feser is non-corrosive so you wouldn't benefit much from it. I've had 3 liquid cooled pc's in the the past and haven't cleaned the liquid cooling loops but about once every 3ish years if using non-corrosive liquid. I'd say just watch your temps and consider cleaning them if they start getting higher than normal.
Not sure how to best instruct you as to cleaning them, it's not really something I've done- the liquid cooling loops I've had experience with in the past are very low maintenance, I don't suspect these are really any different.
tju76
Posted: 14 Jun 2012 at 6:44pm |
thank you for your answer
