Titan X in Bolt II?Post Date: 2015-03-20 |
Moxer
Newbie Joined: 20 Mar 2015 Online Status: Offline Posts: 2 |
Topic: Titan X in Bolt II? Posted: 20 Mar 2015 at 10:08am |
Apologies if this is not posted in the correct section.
I bought a Bolt II in August of last year. I was wondering if the new NVidia Titan X card would fit in my Bolt II if I wanted to upgrade video card this spring. I have the 600W power supply so I think I'm good from a power standpoint. Not sure about the necessary power connectors or dimensions though. Thanks! |
Quote Reply Posted: 20 Mar 2015 at 10:34am |
Bolt II has either a 500W or 700W PSU, but either should work with the Titan X...if you recall, the Titan Black and 780 Ti also worked with either. The Titan X has a two slot width, so yes it will work with your chassis. Only the Titan Z that has a 2.5-slot width will not work.
Moxer
Quote Reply Posted: 20 Mar 2015 at 10:38am |
Yeah, sorry, 700W is what I meant. Ok, awesome! Thanks for your reply!
Quote Reply Posted: 20 Mar 2015 at 11:05am |
Just to confirm, yes. There shouldn't be any issues.
kriscahya
Newbie Joined: 05 Apr 2014 Online Status: Offline Posts: 21 |
Quote Reply Posted: 10 Apr 2015 at 11:39am |
I have the 500W bolt 2, so titan X will fit? And 500W is enough?
Quote Reply Posted: 10 Apr 2015 at 1:41pm |
It might work, but not suggested. You can give it a try if you really want to, but if you see issues, you'll need to purchase a 700W PSU from us which will cost $175, our team can help get an order in for you with this.
kriscahya
Quote Reply Posted: 10 Apr 2015 at 5:03pm |
Oh sweet I'd rather purchase the 700psu and if it is possible kindly include tutorial how to replace the psu
Quote Reply Posted: 11 Apr 2015 at 11:39pm |
Alex, is this still the 80+ gold-rated or bronze-rated PSU? FSP now has 80+ platinum-rated PSU's, of which the 700W unit has only one fan, instead of two in series.
And I'm highly doubting that even with a Titan X (with the peaky power draw of the new Maxwell chips it uses) in a Bolt II will the power peak above 450W, where I'd begin to get concerned about needing to upgrade from a 500W to a 700W PSU. --> http://hothardware.com/reviews/Digital-Storm-Bolt-II-Devils-Canyon-Inside?page=10 |
Quote Reply Posted: 12 Apr 2015 at 6:38pm |
Hi, the BOLT II 700W is a bronze rated unit. Since we now have the BOLT 3, we won't be changing that.
kriscahya
Quote Reply Posted: 12 Apr 2015 at 7:37pm |
Hmm, my spec as follow for my bolt 2
Mainboard: Asus Maximus Proc: i5 4570 Memory: DS 8GB Vga: geforce gtx 750 Liquid cooling Psu: 500W So the 700watt psu compatible with my bolt 2 and can run titan x at peak power or 600w on the new bolt 3 Kindly confirm before I place an order, for the psu, since titan x will be available soon in my country |
