the machine is dead long live the machine!Post Date: 2008-04-12 |
Davethehun
Guest |
Topic: the machine is dead long live the machine! Posted: 12 Apr 2008 at 6:55pm |
Hello,
looking for a mildly futureproofed value optimized (i.e. cheap) computer.
questions:
which is better given I wish to avoid stage 3 cooling expenses the e8400 or q6600?
Should I go with the least expensive motherboard or is that unwise?
do I need the 800mhz memory? is the dominator helpful given I probably won't be overclocking? am I better off buying the e8200 and getting it OCed? Like my last machine, I intend to keep it until it dies, will any OC shorten its natural life?
is the 8800GT the videocard value sweetspot at the moment, or is there a better choice? is the gt a 45nm
Thanks for all input,
DtH
Case: Digital Storm 650Si (Black Anodized Aluminum Finish)
Power Supply: 550W Corsair HX (Dual SLI Compatible) (Silent Edition) Processor: Intel Core 2 Duo E8400 3.00GHz (1333MHz Front Side Bus) (6MB Cache) Motherboard: nVidia 650i Core 2 Quad (nForce 650i Ultra) Memory: 4GB DDR2 Corsair at 800MHz Dominator DHX (High-Performance) Floppy / Card: - No Thanks Hard Drive 1: 500GB Western Digital (16MB Cache) (7200 RPM) (SATA) Hard Drive 2: - No Thanks Raid Option: - No Thanks Hard Drive 3: - No Thanks Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) Optical Drive 2: - No Thanks Network Card: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: nVidia GeForce 8800GT 512MB TV Tuner: - No Thanks Sound Card: Motherboard Multi-Channel High Definition Audio Physics Card: - No Thanks Cooling: Air Cooled Stage 2 (Silent Artic Cooling Heat-sink Upgrade (Copper Heatpipes) Case Lighting: - No Thanks Round Cables: - No Thanks User Manual: Personalized Platinum Digital Storm Binder (Includes Paperwork/Benchmarks/CDs/Manuals) Overclock Processor: - No Thanks, Please do not overclock my processor Overclock Video Card: - No Thanks, Please do not overclock my video card(s) Overclock Memory: - No Thanks, Please do not overclock my memory Tweak Windows: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows Vista Home Premium (64-Bit Edition) (For Enthusiasts) Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based) Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Pre-Install Game: - No Thanks LCD Display: - No Thanks Surge Shield: APC 650VA Uninterruptible Backup Surge Conditioner (Recommended) Speakers: - No Thanks Keyboard: Microsoft Multimedia Desktop 2.0 (Multimedia Keyboard + Optical Wheel Mouse) Mouse: - No Thanks my keyboard comes with a mouse Warranty: 3 Year Platinum Care Extended Parts & Labor Warranty Support: Lifetime Toll-Free Platinum Care Technical Support |
Tyler Lowe
Newbie Joined: 14 May 2008 Online Status: Offline Posts: 0 |
Quote Reply Posted: 12 Apr 2008 at 8:50pm |
questions:
The E8400
If you are not overclocking, even the least expensive options DSO offers are very solid choices. If you are not trying to "set the world on fire" so to speak, with your overclock, these boards are still very good. do I need the 800mhz memory?
No, but it is your best value selection. Is the dominator helpful given I probably won't be overclocking? No. Go with the XMS. Am I better off buying the e8200 and getting it OCed? For a truly budget minded build, I would be tempted to go this route, but that brings us back to the motherboard and cooling. Like my last machine, I intend to keep it until it dies, will any OC shorten its natural life? A conservative overclock will not shorten the life of a CPU to any appreciable degree. Keep in mind, these chips are spec'd to run in low quality mass market computer cases with stock cooling, hooked to low quality voltage regs on crumby motherboards while drawing power from a low quality power supply. Compare that to running in a case with excellent airflow, a great power supply feeding clean power to a motherboard with decent voltage regulation, and a high quality aftermarket cooling solution, only with a mild overclock. If anything, comparing these two situations, my money would be on the overclocked chip for life expectancy. is the 8800GT the videocard value sweetspot at the moment, or is there a better choice? Depending on the resolution you game at, I might call the 9600GT the better value currently, but both cards are excellent. Is the gt a 45nm? No. Thanks for all input,
DtH
