swtor loading issuesPost Date: 2012-03-09 |
sinner.mcmanus
Newbie Joined: 04 Feb 2012 Online Status: Offline Posts: 22 |
Topic: swtor loading issues Posted: 09 Mar 2012 at 6:12pm |
hey i just bought a ode lvl 4 and i booted it and installed tor and when i actually loaded the game it freezes like instantly idk what is going on plzz help
wisepoiboi
Newbie Joined: 28 Dec 2011 Online Status: Offline Posts: 56 |
Quote Reply Posted: 09 Mar 2012 at 9:38pm |
Did you do a clean install or did transfer all your files from your previous computer setup?
Quote Reply Posted: 10 Mar 2012 at 6:42am |
Try other games to see if it's the rig or games themselves. If the game, re-install and maybe do a driver update on your gpu's.
Quote Reply Posted: 10 Mar 2012 at 8:20am |
After you install the game you should download any new patches or updates from the software vendor. This is especially true if you buy a DVD.
Frank |
sinner.mcmanus
Quote Reply Posted: 10 Mar 2012 at 8:41am |
i installed it from disk and now they are telling me to make a new admin account on my pc and reinstall
this is sooooo frustrating |
sinner.mcmanus
Quote Reply Posted: 10 Mar 2012 at 11:36am |
yeah so i made sure to the best of my knowledge that the drivers 4 everything were up to date and installed so i am installing game now downloading it offline but idk, hopefully that will work
Quote Reply Posted: 10 Mar 2012 at 12:26pm |
Try this.......after installing from the discs, go to the swtor website and download their client installer. Run that, and it'll just replace defaults on top of the disc install. this will update the launcher and everything should work afterward.
http://www.swtor.com/community/showthread.php?t=9100 ,click on swtor.com/download in blue highlight. This is a fix I found on a search. I don't have the game so... Hope it works.
Edited by bprat22 - 10 Mar 2012 at 12:42pm |
sinner.mcmanus
Quote Reply Posted: 11 Mar 2012 at 6:58pm |
well i havent tried that but i did try installing from the website i have installed dues ex and it is working fine so i just dont understand swtor has had me giving them various logs and such and they are looking into the problem but i will try that as well i also heared that the fact that my cards use dx11 and the game is on dx9 may be a problem...idk
Tøxie
Newbie Joined: 15 Feb 2012 Online Status: Offline Posts: 23 |
Quote Reply Posted: 12 Mar 2012 at 4:12pm |
SWTOR is using antiquated graphics technology and has been the bane of many computers with newer GPU's. Mine included, I have been having random crashes from SWTOR, but I can play Crysis 2, BF3, Syndicate, and WOW with no issues, so I just assume its a Bioware issue with driver support and GPU support. Though it could also be a driver issue, or a mix of the two.
joebrodude
Newbie Joined: 02 Feb 2012 Online Status: Offline Posts: 22 |
Quote Reply Posted: 21 Mar 2012 at 4:48pm |
I had an issue running in also until I disabled one of the cards in my rig. SWTOR doesn't support SLI
