Subzero liquid cooling stage 3 question
Post Date: 2012-05-21
tybalt View Drop Down
  Quote tybalt Quote  Post ReplyReply bullet Topic: Subzero liquid cooling stage 3 question
    Posted: 21 May 2012 at 4:43pm
I was wondering what fluid ds uses? Do they put any add ins like Swiftech hydrx or Fluidxp? I heard that adding these to your liquid cooling system helps reduce the wear and tear on the system
Intel Core i7 3770K 4.5 GHz
ASUS P8Z77-V DELUXE
8GB DDR3 1600MHz
(120GBSSD 1TB hard drive)
NVIDIA GeForce GTX 670 2GB (Overclocked EVGA)
Asangard View Drop Down
Digital Storm Live Chat Rep.
  Quote Asangard Quote  Post ReplyReply bullet Posted: 21 May 2012 at 7:34pm
Hi tybalt
DS uses Feser One Cooling Fluid.  It contains ethylene glycol.  Here is a quote from the bottle. "Ready to use anti-corrosion fluid.  Protects copper, aluminium, brass and nickel."  Then it says: "Do not mix with other liquids".
I hope that helps.
  Quote tybalt Quote  Post ReplyReply bullet Posted: 21 May 2012 at 8:07pm
Thanks asan! Exactly what I was looking for. Just wanted to make sure it wasn't just water. Thanks again
ASUS P8Z77-V DELUXE
8GB DDR3 1600MHz
  Quote Alex Quote  Post ReplyReply bullet Posted: 21 May 2012 at 11:15pm
Nope, no water. Big%20Smile
  Quote tybalt Quote  Post ReplyReply bullet Posted: 22 May 2012 at 12:10am
One last question about it... Does anyone know the maintenance on it? Do you have to flush it? Will I have to add more fluid later? Thanks again alex and asan
ASUS P8Z77-V DELUXE
8GB DDR3 1600MHz
surf71zx View Drop Down
  Quote surf71zx Quote  Post ReplyReply bullet Posted: 22 May 2012 at 7:00am
Its recommended to be done every 3 years. Your fluid levels do drop.Order a bottle of the Feser and they will send it with your computer.
  Quote tybalt Quote  Post ReplyReply bullet Posted: 22 May 2012 at 10:07am
Good to know! I'll set a reminder when I get my comp. Want this thing to last! Thanks surf
ASUS P8Z77-V DELUXE
8GB DDR3 1600MHz
FR3SHM3AT View Drop Down
  Quote FR3SHM3AT Quote  Post ReplyReply bullet Posted: 22 May 2012 at 12:40pm
 Heres what stage 3 looks like.
but go with stage 4 if you can.
[Compression Fittings]
your going to love your system
                   Love
oops forgot to ad.
The video was taken 15 months after I received system.
I have'nt had to ad fluid yet.
Edited by FR3SHM3AT - 22 May 2012 at 12:41pm
  Quote tybalt Quote  Post ReplyReply bullet Posted: 23 May 2012 at 11:12am
Ya didn't have the cash for stage 4 :-/ but thanks for the video dam ur set up looks hella clean! Can't wait for my comp just happy it's coming... No pc gaming for the last 5 months has sucked!
ASUS P8Z77-V DELUXE
8GB DDR3 1600MHz
This page was generated in 9.277344E-02 seconds.
