SSD to SSD (File Transfer help)Post Date: 2014-01-09 |
MICHAEL2A
Groupie Joined: 24 Oct 2009 Online Status: Offline Posts: 241 |
Topic: SSD to SSD (File Transfer help) Posted: 09 Jan 2014 at 11:55pm |
Hey guys, I've read a few articles on this but can't decide the best method to use. Basically, I'm looking to purchase another SSD and want to transfer all the files that are not OS files to the new SSD leaving just the OS on the Primary SSD.
Is cloning the drive the only way to do this or can I set up the partitions on the new drive and just transfer the files I want to transfer without a complete clone?
After doing this I want to clean up the Primary OS drive by wiping the tranfered data from it. Would CCleaner be the best program to erase specific cells leaving the OS alone?
NZXT Switch 810
Asus Rampage V ED10 16GB Corsair Platinum 3000mhz i-7 X5960, 3.0Ghz-3.5Ghz Intel 750 800GB NVME-SSD Corsair H115i CPU Cooler 2 Asus Strix 1080 8GB SLI Corsair AXi 1200 PSU |
fstcvc
Quote Reply Posted: 10 Jan 2014 at 12:38am |
General files could be moved by cut/copy/paste (drag & drop) method. Anything else like software or games will most likely need to be uninstalled and then reinstalled (I believe Steam allows you to move your directory to a new drive). Attempting to just move program files will most likely result in them not working anymore due to incorrect registry settings and locations of where it thinks everything is at...
HailStorm II
MICHAEL2A
Quote Reply Posted: 10 Jan 2014 at 9:22pm |
Well, that stinks. Do you know if cloning would work without corrupting program files? Edited by MICHAEL2A - 10 Jan 2014 at 9:23pm |
NZXT Switch 810
fstcvc
Quote Reply Posted: 10 Jan 2014 at 11:38pm |
If you're doing a full 1:1 clone you'll be fine. It's only an issue if you're trying to split apart the OS from everything else...
HailStorm II
MICHAEL2A
Quote Reply Posted: 15 Jan 2014 at 12:47pm |
Thanks fstcvc, sorry for the late reply. Do you know if it is possible to do a partial clone? For instance, can I move all files except the OS? |
NZXT Switch 810
fstcvc
Quote Reply Posted: 15 Jan 2014 at 10:08pm |
A clone is exactly that - an exact duplicate of what you already have.
HailStorm II
ZyloWolfBane
Newbie Joined: 27 Feb 2014 Online Status: Offline Posts: 19 |
Quote Reply Posted: 05 Mar 2014 at 3:46pm |
Some SSDs like those from Samsung give you the software to copy everything to the new drive for you also.
