Soundcard Question.
Post Date: 2014-07-23
MannyBerry View Drop Down
  Quote MannyBerry Quote  Post ReplyReply bullet Topic: Soundcard Question.
    Posted: 23 Jul 2014 at 5:42am
So my system is on stage 4 (and I'm freaking excited) so I figure I'll pass the time by asking questions which are probably obvious but I should ask anyway.
I got the MAXIMUS VII HERO by Asus which boasts native 7.1 ROG SupremeFX Audio but I also got a Creative Sound Blaster Z card because I wanted dedicated audio.
My question is, should I plug my headphones and microphone to:
The motherboard
The sound card directly
or the inputs on my computer case (CM Storm Stryker)
Not sure!
Hailstorm II
Intel Core i7 4790K 4.0 GHz
ASUS MAXIMUS VII HERO
16GB DDR3 1866MHz Corsair Vengeance Pro
NVIDIA GeForce GTX 780 Ti 3GB
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 Jul 2014 at 6:00am
To use the sound card, you'll need to use its own outputs.  If you plug into the motherboards audio on the back then you're on the Hero's audio.
Most sound cards do have a front panel audio connector on the sound card itself, inside the case where it mounts, to connect the sound card to the front panel audio of your pc case.   Not sure if DS sets it up that way, but my guess is they leave the front panel to the mobo.
Not sure about the compatibility of the front panel plug to the mobo and the sound card.  That you'd have to look into.
Hope this helps.   Big%20Smile
Edited by bprat22 - 23 Jul 2014 at 6:05am
  Quote MannyBerry Quote  Post ReplyReply bullet Posted: 23 Jul 2014 at 6:47am
You're always helpful man, I appreciate it :)
Sound card it is.  Makes sense when you think about it but I wasn't sure.
I'm not even sure if the sound card will provide higher quality audio than the motherboard at this point.
Hailstorm II
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 Jul 2014 at 7:40am
My pleasure. Big%20Smile
