SLI - 1 card for Graphics-The other for Physics?Post Date: 2014-07-17 |
Clay
Topic: SLI - 1 card for Graphics-The other for Physics? Posted: 17 Jul 2014 at 3:48pm |
Quick question
Just found out I am getting a Dual setup (long story) Anywho... I heard you can have one card for graphics only and the other for Physics? How do you go about this? I don't have the setup as of yet, it will arrive by next Friday. Thanks for the info! |
I7 13700KF 5.4hz
Quote Reply Posted: 17 Jul 2014 at 5:27pm |
Hi Clay... Physx is setup in the Nvidia Control Panel, under 3D, Surround I believe. You might have to hunt a bit. Once there, select which card is Physx and go for it. If it's a gtx 780 ti and gtx 750 for example, the 750 obviously is the Physx.
I have read and seen benches where you'll get a good 20% boost and others where it did little. Depends what cards you have. I think it should work to take load off your primary card, increase frames, reduce heat on the primary and work fine but I can't say for sure. Give it a go and let us know. Edited by bprat22 - 17 Jul 2014 at 5:28pm |
Clay
Quote Reply Posted: 17 Jul 2014 at 5:31pm |
Thanks! I'm googleing it now. Trying to see what the temps are going to be as well. I know when I ran my single 780 during games, it would max out at about 60c. Been noticing peeps on youtube showing 80c or around there. Wow.
I7 13700KF 5.4hz
