shut down
Post Date: 2012-06-01
saintin67 View Drop Down
  Quote saintin67 Quote  Post ReplyReply bullet Topic: shut down
    Posted: 01 Jun 2012 at 7:28pm
How long does it take for XM15 to shut down or log off?  I used  the guest account and now it takes an unusual long time, when I first got the computer it would say updayting windows.
Orange7 View Drop Down
  Quote Orange7 Quote  Post ReplyReply bullet Posted: 02 Jun 2012 at 6:21pm
I don't know how long it would take with an HDD, but mine takes from three to five seconds with an Intel 520.
DS xm15 Stage 4
i7-3820 (2.7GHz/3.7GHz)
16GB 1600MHz DDR3
GT 630, 1GB
240GB Intel 520
  Quote Orange7 Quote  Post ReplyReply bullet Posted: 02 Jun 2012 at 6:27pm
From what you say though, Windows is automatically installing updates after you shut it down, which is common on a Windows operating system, because Microsoft feels that that the span of time after you are done using the computer will probably be the least intrusive time (which it generally is). However, if you wish to shut down without installing updates, I believe that you should be able to click on the arrow next to the shut down button in the start menu and choose to shut down without updating. This option will only appear when there is a shield next to the shut down button, indicating updates that need to be installed.
DS xm15 Stage 4
16GB 1600MHz DDR3
GT 630, 1GB
240GB Intel 520
This page was generated in 8.984375E-02 seconds.
