MarkNY
Topic: Setup Advice Posted: 12 Jun 2012 at 8:49am |
USD $5500
Smooth gaming on 30" display at 2560x1600
Gaming
Video Card(s): 2x SLI Dual (NVIDIA GeForce GTX 680 2GB (Includes PhysX)
Sound Card: Creative Labs Recon3D Fatal1ty Champion (Includes Front I/O) (PCI-Express Slot Based)
H20 Tube Color: Red Tubing with High-Performance Fluid (UV Lighting Reactive)
Thoughts? Thanks for your help!!
White Aventum
3970X at 4.7Ghz
Asus Rampage IV Extreme
16 GB 2400MHz Memory
2x Nvidia Classified 680 4GB
2x 240 GB Neutron SSD
1x 1 TB WD Caviar
Liquid Cooled CPU/GPU/Chipset
MarkNY
Posted: 12 Jun 2012 at 8:59am |
PS What type of credit cards does DS accept?
White Aventum
3970X at 4.7Ghz
1x 1 TB WD Caviar
Orange7
Posted: 12 Jun 2012 at 9:19am |
Discover, Mastercard, and Visa.
Also, I don't have any definite tips for the build , because I am not sure exactly what you wanted, but here are a few minor tweaks that would depend on your preferences:
-If you have no plans on upgrading, you could probably downgrade the PSU to something that is just dual SLI compatible.
-I do not know if you are going to use a Blu-ray player or not, but if your not, switching it back to the original CD/DVD player would save a few hundred.
-Also, unless you are an audiophile, the sound card is probably unnecessary.
I hope this helps, and congrats on the nice rig.
Edited by orange.seven7@gmail. - 12 Jun 2012 at 9:30am
DS xm15 Stage 4
i7-3820 (2.7GHz/3.7GHz)
16GB 1600MHz DDR3
GT 630, 1GB
240GB Intel 520
Posted: 12 Jun 2012 at 9:25am |
Configuration looks good to me!
retirednavysnipe
Posted: 12 Jun 2012 at 10:28am |
Mark, That config is exactly as mine is with the exception I have 1600 MHZ ram, different model Power Supply and I have the intel 120 GB SSD.
My Beast runs excellent on a 27" hp monitor haven't found anything that even tries to stress it. I think you will be real happy with what you just put up. My overclock is set right at 4.5 Also liquid cooling keeps everything nice and cool and looks good doing it.
Good Luck with you choices.
John
Hailstorm Black Ops
I7 3930K 4.5GHZ
16GB 1600MHZ ram
2 x GTX 680
120 GB SSD, 1 TB hardrive
Posted: 13 Jun 2012 at 7:22am |
Hi Mark,
With your 2550 monitor you might consider the 4Gb version of the 680. The higher Vram is desirable with higher resolutions. If it is not in the budget then the 2Gb is a good choice.
Hi Mark,
With your 2560 monitor you might consider the 4Gb version of the 680. The higher Vram is desirable with higher resolutions. If it is not in the budget then the 2Gb is a good choice.
