SDD Hard Drive
Post Date: 2014-02-16
wright View Drop Down
  Quote wright Quote  Post ReplyReply bullet Topic: SDD Hard Drive
    Posted: 16 Feb 2014 at 2:54pm
Hello everyone, I bought a Hailstorm this past July and I really love my system, however. when I configured it I got the Samsung 256 GB 840 pro and a WD 1TB hard drive for storage. Well my SSD with all my games, OS, ect, has 40 GB left and the WD storage drive has 880 GB. At some point soon I will run out of space on my SSD. I love the SSD because of the speed it loads everything. I need some advice here on what to do about more disc space. If at some point I need to buy a SSD with more GB's how would I move everything from the old ssd to a new ssd and add OS, games without loosing everything. I have most of my games and stuff backed up on the WD storage drive. Anyone that has some ideas I would appreciate some help. Thanks.
Hailstorm ll
i7 4770K OC
Z 87 Chip set
16 GB DDR3 1866 MHz
Stage 2 cool 240mm Radiator
GPU 1x GTX 780 3GB
Samsung 256GB SSD
1TB WD Caviar
Corsair 120mm performance fans
fstcvc View Drop Down
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 16 Feb 2014 at 8:12pm
If you plan on just replacing your smaller SSD for a larger one you should be able to just clone the data from one to the other. Some SSD drives might come with software (or have a free download for one) or you can use a separate drive cloner like Acronis.
HailStorm II
i7 4770K @ 4.5GHz
Asus Maximus VI Extreme
  Quote wright Quote  Post ReplyReply bullet Posted: 17 Feb 2014 at 6:53am
fstcvc, I never really thought about that. Sounds like just the solution for me. I have never cloned anything. Is it very difficult? That is exactly what I won't to do is move to a larger SSD. Are there any instructions that shows you how to do that?  Thanks so much for that idea.
Hailstorm ll
i7 4770K OC
Z 87 Chip set
16 GB DDR3 1866 MHz
GPU 1x GTX 780 3GB
Samsung 256GB SSD
1TB WD Caviar
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 17 Feb 2014 at 7:02am
Most cloning software should be similar to that of copying a CD/DVD. Select source and target and let it copy everything over. If there are any options, they might include making the drive bootable and maybe formatting. Other than that it's a 1:1 copy. Replace old drive with new one (so that way you don't have to change BIOS settings on which drive you boot from) and you should be good to go.
HailStorm II
i7 4770K @ 4.5GHz
  Quote wright Quote  Post ReplyReply bullet Posted: 17 Feb 2014 at 5:51pm
Thanks fstcvc for your help, now to get a clone program. I'll try the one you suggested.
Hailstorm ll
i7 4770K OC
Z 87 Chip set
16 GB DDR3 1866 MHz
GPU 1x GTX 780 3GB
Samsung 256GB SSD
1TB WD Caviar
