Hi sandal704...Welcome to the forums.
That's a nice rig you put together, but I would make suggestions.
Dropping the 680's for the 670's is a good move. They perform almost the same and will save alot of $$$.
For the best power supply, change to the 1050HX. It is tops and the 7 year warranty tells of its quality.
Drop the performance fans. All they do is mess with the HafX's great airflow and would be noisier.
Drop the temp control/fan control. It's good for looks but in function the temps aren't accurate and the HafX fans don't need the fan control. It's fans are quiet and already turn at only 700rpm and move lots of air.
You could go with Win7 Pro. It allows you to add more ram above the 16GB if you needed it.
Drop the UV lighting and Red tubing. Those are for true water cooling like stage 4 and above. The 240mm cooling picked is a sealed unit, like the Corsair H100, and the tubes aren't swappable and the unit requires no maintenance.
Here's the build with the changes.
Config # 692822 Cost $ 4965
Expansion Bay: Internal Digital Media Card Reader (Black)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 670 2GB (Includes PhysX)
Sound Card: Creative Labs Recon3D Fatal1ty Champion (Includes Front I/O) (PCI-Express Slot Based)
Virus Protection: Trend Micro Titanium Internet Security
Display: NVIDIA 3D Vision Surround Setup (3x Triple Asus 3D Panels 23 inch VG236H (Includes 3D Glasses)
The big concern is running a triple 3D monitor setup. That takes alot of graphics power. You might only be able to play certain games like BF 3, etc on medium settings. To play games on higher settings a tri-sli, 3x 670 setup might be required. It all depends on what you play and what settings will make you happy.
Each monitor is 1920x1080 and they each need to render the images twice. That's what 3D does for the effect.
Check it out and see if it fits what you like.
Good Luck.
Edited by bprat22 - 26 May 2012 at 12:55pm
