roadkingbill
Topic: Roadkingbill's computer Review Posted: 03 Jun 2010 at 1:08pm |
Ok my new DS machine has been up and running for a few weeks so it's time pass on some good words to the staff at DS.
Everything for the most came in great shape after removing from the very stought box. Minor problems with one plug undone but an esy fix. First problem I had was at boot up. It failed. A call to DS tech got me up fast. Seems some how the board reset and DS talked me through the OC and other Bios stuff. Well done tech staff !
Specifications: Chassis Model: Digital Storm HailStorm (Black OPS Edition) Exterior Finihttp://img28.imageshack.us/img28/543/056ie.jpgsh: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 930 2.8GHz (Quad Core) Motherboard: EVGA X58 LE Edition SLI (Intel X58 Chipset) (Supports SLI or CrossFire) System Memory: 6GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 1200W Digital Storm Certified (Dual/Triple/Quad SLI Compatible) (Silent Edition Highly Recommended) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (80GB Solid State (By: Intel) (Extreme Performance) (Model: SSDSA2MH080G2R5) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Seagate/Hitachi/Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 22x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x NVIDIA EVGA GeForce GTX 480 1.5GB (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Single Video Card H20 Tube Color:Black Tubing with High-Performance Fluid (UV Lighting Reactive) Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (UV) (Creates Glowing Effect for H20 Tubes) Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks Boost Processor: FREE: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Requires Air Cooling Upgrade) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: Memory Fan Kit Only (Does not include memory overclocking service) Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: FREE: Please include a free copy of a hot-selling game Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Large) Priority Build: - No Thanks, Ship Within 5-15 Business Days After Order Is Successfully Processed Warranty: 3 Year Platinum Care Extended Parts & Labor Warranty
Ok my biggest complaint is the coolin fans on the rads. Its freaken loud. I requested, begged, posted called.... about my conserns regarding noise level and was assured it would be quiet. Well I guess what one person thinks is quiet is sure differnt from mine. I went into the bios and was unable to change the rpm's but the are stuck at 100 % which was strange. Its like a jet running in the distance lol
Other than the fan noise issue I am very happy with my purchase.
I cound not resist in adding a pic of my other "machine"
Bullseye
Posted: 03 Jun 2010 at 1:12pm |
Awesome dude it looks like you'll have alot of fun with it! What games do you play on it??? I also noticed a box with 2 fans what is it for??
Edited by Bullseye - 03 Jun 2010 at 1:16pm
roadkingbill
Posted: 03 Jun 2010 at 1:20pm |
Right now I am catching up on games. Fallout 3 with mods is my fav, alone with WW2 Online, Mass Effect 2 and Dragon Age. What fans are you asking about ?
justin.kerr
Posted: 03 Jun 2010 at 1:22pm |
 I searched your build thread, here is a quote
quote "the zalman F3 fans, if that is what is on your radiator, are not a little loud, they are deafening loud IMHO"
Bullseye
Posted: 03 Jun 2010 at 1:52pm |
Yup those ones
roadkingbill
Posted: 03 Jun 2010 at 2:07pm |
Hmm i did not ask for any upgrade fans.
justin.kerr
Posted: 03 Jun 2010 at 2:10pm |
I seen a few posts in your build thread stating that the liquid cooling was very loud, unless you asked for special fans, or to reduce the voltage to slow the loud ones down.
Bullseye
Posted: 03 Jun 2010 at 2:18pm |
so what are those fans doing there??
Posted: 03 Jun 2010 at 2:32pm |
Originally posted by roadkingbill
Other than the fan noise issue I am very happy with my purchase. |
You will also need to get an adapter that turns the 3pin fan option to molex so you can use it.
Posted: 03 Jun 2010 at 2:35pm |
Oh and I forgot to say, great system!
justin.kerr
Posted: 03 Jun 2010 at 2:45pm |
why can't you adjust fan that are on a Molex? I do it all the time. lol
roadkingbill
Posted: 03 Jun 2010 at 2:48pm |
Well i did request the fans be "quiet". I was going to get Scythe GentleTyphoon 120 mm but after talking to Sara and with the add one fees it just got to expensive.
roadkingbill
Posted: 03 Jun 2010 at 2:53pm |
Would this work ?
Zalman MFC2 Multi Fan and Temperature Monitor and Control Drive Bay Device
Bullseye
Posted: 03 Jun 2010 at 2:54pm |
yeah that tends to happen
Posted: 03 Jun 2010 at 3:18pm |
Originally posted by justin.kerr
why can't you adjust fan that are on a Molex? I do it all the time. lol |
I was thinking that since the fan is plugged in via molex, you can't plug it into a motherboard header pin to adjust fan speeds via BIOS. Unless you have another way of doing it? Such as the Zalman adapter or simply getting a molex to 3 pin adapter and plugging it straight into the motherboard fan headers?
Edited by Alex - 03 Jun 2010 at 3:18pm
Posted: 03 Jun 2010 at 3:20pm |
Well i did request the fans be "quiet". I was going to get Scythe GentleTyphoon 120 mm but after talking to Sara and with the add one fees it just got to expensive. |
I understand, but, there's not much we can do to slow them down unless you purchased the noise reduction package even without the foam and just pay half of the package fees just to ensure we add the Zalman quiet adapters to the fans.
We can still send them to you, or help you find some so you could still resolve the noise issue rather quickly and easily.
Edited by Alex - 03 Jun 2010 at 3:20pm
Posted: 03 Jun 2010 at 3:21pm |
Would this work ?
Zalman MFC2 Multi Fan and Temperature Monitor and Control Drive Bay Device |
Yes, that can work, however, you will need to route the fan cables to the fan controller. You may need to purchase adapters so they can fit the 3 pin ports on the fan controller and even extension cables in order to reach as well.
justin.kerr
Posted: 03 Jun 2010 at 4:07pm |
I have directed some members here to run them at 7 volts, it will quiet them down quite a bit, but also they have to remember that temps will increase some. to run them at 7 volts is easy, and free.
Fan controllers can be great, but I personally have had a lot of them fail, so anymore I just make my own, or use quiet fans.
Edited by justin.kerr - 03 Jun 2010 at 4:07pm
SemperFuzz
Posted: 03 Jun 2010 at 4:43pm |
Nice bike with no finger prints or dust on it. Looks like you need to get some dust rags and cleaner ready and "Do Work" on that case and desk area ahahah
roadkingbill
Posted: 03 Jun 2010 at 4:51pm |
Alex if I would have known about the noise reduction package without the foam I would have purchased that in a heartbeat.
Oh well its still a GREAT system !!!! (minus the fan noise)
ablahblah
Posted: 03 Jun 2010 at 5:08pm |
Fan controllers can be great, but I personally have had a lot of them fail, so anymore I just make my own, or use quiet fans. |
yep, justin's instructed me on how to reduce to 7v, it's ridiculously easy, free, safe, and it works on a molex connector, yellow sends 12v, red sends 5v, and black wires are ground. naturally, yellow + black = 12v. connect red and black and you get 5v. interestingly enough, if you connect yellow and reg, you get 7v (subtract the two). to do this, get a thin paper clip, small flat head screwdriver, whatever fits around a molex pin. rip out the black wire it's connected to, and replace it in the slot where the red wire would normally be. just remind yourself that you shouldn't use the passthrough on the molex adapter, unless you wired up the passthrough the original way and make sure to remind yourself that the wires are color coded incorrectly now.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
justin.kerr
Posted: 03 Jun 2010 at 5:21pm |
I have done a few tests with the foam, and there is little to no difference in temps. Also I use 2" thick acoustical foam that you would find in a recording studio, the thin stuff does not do much, but it does help a bit.
Posted: 03 Jun 2010 at 5:48pm |
Oh well its still a GREAT system !!!! (minus the fan noise) |
Understood. Perhaps we can start to offer a package without the noise dampening foam. I'll talk to the team about it. You do definitely have a lot of options to quiet them down. If you need help feel free to get in touch with us directly.
Bullseye
Posted: 04 Jun 2010 at 4:47am |
That would be great for people who can't get LC because it's cheaper and it works!
rholyrag
Posted: 04 Jun 2010 at 5:29am |
Great looking rig! Thank you for sharing.
roadkingbill
Posted: 07 Jun 2010 at 1:49pm |
Couple of other issues. i noticed on another build that his computer had three case badges on it. Mine only recieved one small case badge
This is a review of my system with pics, why has it not been moved to the review section ? :(
Posted: 07 Jun 2010 at 5:01pm |
This is a review of my system with pics, why has it not been moved to the review section ? :( |
Sometimes our customers ask us to place special extra branding if possible on the system.
We'll be more than happy to send you some extras, feel free to contact us directly for details.
I'll move your review over now. Sorry for the delay, I've been very busy  .
