Repetitive rebootingPost Date: 2014-10-15 |
Aka
Groupie Joined: 25 Jan 2011 Online Status: Offline Posts: 208 |
Topic: Repetitive rebooting Posted: 15 Oct 2014 at 8:39am |
Started my pc up for the first time in a few months due to moving and now it gets to the windows 7 screen thn reboots itself after a quick blue screen tht scrolls through tht I can't read I've reseated everything loaded defaults from bios and still same outcome I'm scratching my head here any help would b awesome
Hafx 2600k P67 deluxe asus mobo Sli 570 Corsair 1000w Edited by Aka - 15 Oct 2014 at 8:51am |
Quote Reply Posted: 15 Oct 2014 at 8:46am |
If you can get to the desktop at all. then use Bluescreenview or WhoCrashed and and open it after the next crash. It'll give you info on the cause.
Have you reseated the graphics card and ram sticks? Make sure the power plug into the back is seated all the way in. It can be a tight fit. Plug directly into a wall outlet for now, not a surge protector or UPS device. Sounds like a loose connection or a short. Check all the wiring to the mobo, drives and fans, even unplugging some just to see if it boots. If the psu is a modular, then check its connections, also. If your mobo has integrated video, then remove the video card, and use the integrated video ports near the usb and audio connections, just to help isolate the problem. Edited by bprat22 - 15 Oct 2014 at 8:50am |
Roykirk
Quote Reply Posted: 15 Oct 2014 at 6:03pm |
If it's restarting just after the Windows 7 logo starts during boot, it may be that somehow the SATA driver isn't matching your SATA mode in BIOS. Should be running in AHCI unless you have a RAID configuration. You could check the mode in BIOS to match what you have. May have gotten corrupted somehow.
Aka
Quote Reply Posted: 15 Oct 2014 at 7:46pm |
Tyvm both of u for the fast replies I've reseated both ram and gpu's and no change also reseated all cables to mobo. I'm not sure how to connect video on mobo panel only thing my monitor has is dvi and Hdmi. Hopefully some more troubleshooting will resolve the issue
Quote Reply Posted: 16 Oct 2014 at 2:53am |
Just saw your specs. Not sure if I missed it or you added them to help us.
That mobo doesn't have onboard video, so no way to follow that suggestion. I would remove one of your 570s and try just one at a time. Also try one card at a time, swapping between the different Pcie slots. Good luck. |
Aka
Quote Reply Posted: 16 Oct 2014 at 9:41am |
Thnx bpratt ya I've tried swapping the cards no difference unfortunately only thing I can think of is somehow the hard drive got corrupted somehow cause it gets to the windows 7 splash screen thn reboots guess I'm gonna try a fresh install really hate to I'm gonna loose everything. in the move I misplaced my discs with backups etc
Edited by Aka - 16 Oct 2014 at 10:00pm |
