Removing fan from water cooling system.
Post Date: 2012-08-12
Nebidimka View Drop Down
  Quote Nebidimka Quote  Post ReplyReply bullet Topic: Removing fan from water cooling system.
    Posted: 12 Aug 2012 at 4:22am
Hello everyone, after 1,5 years of service one of my fans on top radiator broke (262RPM instead of desired 1600-1800). The system is dual loop and the case is 800d, I also added photos to show you how it looks. I need help because I don't know if I will neeed to drain the system and what screws  to unscrew. Oh and yes I did turn off that fan because it was making not normal noise.
P.S. Also figured I need to clean the dust lol
Yes I couldnt figure out how to show images on the forum. (actually I was too lazy)
http://s1.uploads.ru/i/C40kl.jpg
http://s1.uploads.ru/i/ufX0G.jpg
http://s1.uploads.ru/i/8NILD.jpg
Edited by Nebidimka - 12 Aug 2012 at 4:23am
tju76 View Drop Down
  Quote tju76 Quote  Post ReplyReply bullet Posted: 12 Aug 2012 at 6:33am
Hmm you might have to it will be hard to remove the radiator to install the new fan without completly removing the rad from the case but this is just my opinion
  Quote tju76 Quote  Post ReplyReply bullet Posted: 12 Aug 2012 at 6:36am
Damn you got some serious dusting to do, the best thing is to clean your pc atleast once a month dust can really damage electronics and negativly affect performance enough dust build up on fans can also cause them to stop working from what I have heard, never had the issue keep mine clean as a hospital operating room
  Quote Nebidimka Quote  Post ReplyReply bullet Posted: 12 Aug 2012 at 6:41am
I do wipe electronics, tubing less often :D
BTW guys do you think using automatic screwdriver is viable? Because screws on the left side are impossible to unscrew.
Edited by Nebidimka - 12 Aug 2012 at 6:47am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 12 Aug 2012 at 6:49am
I'm gonna take a guess here and say the 12 screws on top, 4 for each fan, go through the case, through the fan and into the rad.  If you remove all screws the rad might drop enough to slide out the old fan.
I can't believe it would be more complicated than that, but I can't say for sure.
Good Luck and maybe someone with first hand will weigh in, or just pull the screws and see.  Support the rad from below.
 Small screws I do by hand.  Power drivers can strip the heads.
Edited by bprat22 - 12 Aug 2012 at 6:52am
  Quote Nebidimka Quote  Post ReplyReply bullet Posted: 12 Aug 2012 at 7:46am
http://uploads.ru/?v=XKJZy.jpg
As you can see screws are already messed up (not by me) Any thoughts?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 12 Aug 2012 at 8:20am
It might be the picture doesn't do it justice, but they don't look bad to me.  I would get a phillips head that fits it right, nice and snug and bottomed out, and while trying to turn it, tap the end of the handle with your palm.  Or, use both hands and have a helper tap the handle with a small hammer while you press down and turning.   Not a whack, but just tapping to vibrate it loose.
I'm sure it's easier said than done.    Don't know why it would've been mounted so tight?
  Quote Nebidimka Quote  Post ReplyReply bullet Posted: 12 Aug 2012 at 8:26am
I dont know :D Didnt really notice untill fan started making noise. Maybe somebody in DS has really strong hands lol
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 12 Aug 2012 at 8:34am
Yep, they must have a weight lifter doing assembly.Big%20Smile  Jack Armstrong is the name we used when we had the problem.
If all else fails, then a trip to Sears, etc for a Easy Out Screw extractor might be the solution.  Problem is you have to drill a small hole and ya don't want metal slivers getting into the case.  Put the case on its side, damaged screws on low side and go slow.   That is last resort.
Good luck.
One trick that has helped me on occasion, if all else fails, is to take a small flat head screwdriver, put the end at a 45 dgree angle or little lower into one of the slots towrd the outside edge and hit with a hammer to break it free.
Edited by bprat22 - 12 Aug 2012 at 8:45am
Tidgxor View Drop Down
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 12 Aug 2012 at 10:30am
I think ole' Jack might have assembled my rig too, when I first got it I had to use the force of the gods to take the side fan off the HAF-X, Big%20Smile
Asangard View Drop Down
Digital Storm Live Chat Rep.
  Quote Asangard Quote  Post ReplyReply bullet Posted: 12 Aug 2012 at 2:37pm
Hi Nebidimka,
My older DS rig is the 800D case and I had to replace 2 of the top fans.  Those fans in my case were attached to the radiator.  When I removed the top 12 screws the radiator with the fans attached dropped down.
I was able to slide the radiator out of the case enough to remove the fans without having to remove it from the cooling loop.
You will need a narrow shaft phillips head screw driver that will pass through the top holes of the fan to reach the screws that hold the fan to the radiator.
I hope this helps.
  Quote Nebidimka Quote  Post ReplyReply bullet Posted: 12 Aug 2012 at 3:44pm
Originally posted by Asangard
Hi Nebidimka,
I hope this helps.
Thank you very much. Now I need to buy a set of good philips screwdrivers :D
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 12 Aug 2012 at 6:22pm
Awesome
  Quote Asangard Quote  Post ReplyReply bullet Posted: 12 Aug 2012 at 7:42pm
Glad to be of help.  Let us know how it goes.
Edited by Asangard - 12 Aug 2012 at 7:43pm
  Quote Alex Quote  Post ReplyReply bullet Posted: 13 Aug 2012 at 12:16pm
Awesome, I love how helpful everyone is!
pos View Drop Down
  Quote pos Quote  Post ReplyReply bullet Posted: 13 Aug 2012 at 3:14pm
Nebidimka, If all else fails you may want to try a reversing drill bit. I use this at work sometimes on small screws and bolts. When you drill in reverse it grabs the head and backs it out. You may have to look on the net, I don't ever remember seeing them in any stores. At work we get them from grainger supplys. Hope this helps.
the pos Loves His ODE3
This page was generated in 0.1399994 seconds.
