Recommended Monitors for Gaming and Professional
Post Date: 2011-11-27
Page  <1 456
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Nov 2011 at 6:14pm
OK then you got it figured out, this is an ips monitor so image quality is great
crawlins View Drop Down
  Quote crawlins Quote  Post ReplyReply bullet Posted: 25 Feb 2012 at 10:48pm
Any suggestions for a 27" monitor for gaming for around $300 or so?
Neens View Drop Down
  Quote Neens Quote  Post ReplyReply bullet Posted: 28 Feb 2012 at 7:18pm
DST you seem to be the monitor expert here so I'm directing this at you. I just ordered an ODE lvl 4 so it will be running 2 of the 7970's. My question is will that be enough to run a dell u3011 on high settings or should I go with a smaller lower res monitor?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 29 Feb 2012 at 12:04pm
DST hasn't been around lately so I'll give it a go.
The ODE 4 will play just fine on the 30" Dell at it's native resolution of 2560x1600.
The cf 7970's replace the previous ODE 4 of tri-sli 570 1.2GB cards and have a similar performance according to Alex.
  Quote Neens Quote  Post ReplyReply bullet Posted: 29 Feb 2012 at 1:58pm
Thanks bprat. I noticed after I posted that he hasn't logged in for a month.
wisepoiboi View Drop Down
  Quote wisepoiboi Quote  Post ReplyReply bullet Posted: 04 Mar 2012 at 5:59pm
Hey if you didn't get a Screen yet i just got one from newegg, its on sale heres a link at the one i got
 http://www.newegg.com/Product/Product.aspx?Item=N82E16824236103
I believe the sale ends on 3/8 so get it while you can.
wkroll View Drop Down
  Quote wkroll Quote  Post ReplyReply bullet Posted: 10 Apr 2012 at 1:38pm
Could someone help me;
Comp specs, I52500k Nvidia 560ti 8gig of ram.
Looking to buy one of these dell monitors,  biggest size my current vid card can handle.   Seems like everyone is recommending the UltraSharp Monitors?
My current monitor is a DELL about 6 years old 1600 X 1200,  would it be worth upgrading?
Recommendations?
Thanks,!
  Quote FrankW Quote  Post ReplyReply bullet Posted: 10 Apr 2012 at 2:08pm
Hi wkroll,
You night get more help if you start your own thread. Sometimes an add on like this gets lost in all the post.
If you are operating at 1600 x 1200 then I think you will see a big inprovement in a new monitor. Especially if you go for one of the Dell Ultra Sharps. Take a look at the 2312HM. You can get it for less than $300 and has an IPS screen. 1920 x 1080 resolution.
Doxiedad View Drop Down
  Quote Doxiedad Quote  Post ReplyReply bullet Posted: 15 Jun 2012 at 2:07am
Now that I've got my Marauder LVL 3 I need a new monitor. After reading through this thread I'm leaning towards a Dell ultra sharp.
My current monitor is a Gateway 21" 1680x1050. My rig has a Radeon HD 7850. I'd like to step up to 1920x1080. I'm thinking the U2212HM or U2312HM will be a nice upgrade.
Would I be able to push WoW and Diablo 3 at max settings on either of those monitors?
Also are IPS monitors really worth the extra $$ over a regular monitor?Ld
  Quote FrankW Quote  Post ReplyReply bullet Posted: 15 Jun 2012 at 7:47am
HI Doxiedad,
The 7850 is a pretty good GPU that exceeds the 560Ti and catches the 570 in some games. As long as you stay away from Crysis Warhead you will be good with your 7850. With some games you might have to turn down your AA settings to keep your FPS up.
I have never seen any TN monitor that has as good of a picture as an IPS monitor. If it is in your budget I would go for the 2312HM. If not, then go for the 2212HM and save a few bucks. An IPS monitor will have better color and detail. Both of the Dell monitors have 1920 x 1080 resolution.
  Quote Doxiedad Quote  Post ReplyReply bullet Posted: 15 Jun 2012 at 8:10pm
Frank,
Thanks for the help. Are all IPS monitors the same or is there something that makes the Dell ones better? I found one locally and was wondering how it compared to the Ultrasharps. It's a LG IPS235V
Thanks.
Edited by Doxiedad - 15 Jun 2012 at 8:11pm
  Quote Doxiedad Quote  Post ReplyReply bullet Posted: 15 Jun 2012 at 11:53pm
Never mind the LG doesn't look like a good bet. So now it to decide between the 2212HM, 2312HM, or 2412M, or possibly the Asus VH242H?
Edited by Doxiedad - 16 Jun 2012 at 12:03am
  Quote FrankW Quote  Post ReplyReply bullet Posted: 16 Jun 2012 at 6:03am
Doxiedad, all of these lower cost IPS monitors use the same LG screens. I have a NEC Multisync 23" and it uses the same LG screen as DELL. I am not sure who builds the Dell monitors. The difference between the lower cost IPS monitors are the electronics. I believe Dell sells the most of this monitors and has a history of good performance. Go to Amazon and Newegg and read the reviews of the different IPS monitors. You will find that some have more problems than others. Most complaints of IPS monitors are by people who do a lot of color work and have special requirements, not gamers.
I can't recommend any IPS monitor over others as buying a monitor is some what of a crap shoot. There is always a chance that any monitor might have some small problem. Judging from the good results that DS members have with the DELL, I think it is a good choice. But I don't think it is any better than my NEC.
Edited by FrankW - 16 Jun 2012 at 9:45am
belaflek73 View Drop Down
  Quote belaflek73 Quote  Post ReplyReply bullet Posted: 28 Jun 2012 at 10:18am
Can anyone give their thoughts on this monitor?
Alienware OptX AW2310 23-inch 3D Full HD Widescreen Monitor
$399.99
  • Panel Size : 23" Widescreen
  • Aspect Ratio : Widescreen (16:9)
  • Panel Type : TN - Twisted Nematic
  • Optimal Resolution : 1920 x 1080 (Full HD)
  • Contrast Ratio : 80000:1 (max)
  • Brightness : 400 cd/m2 (typical)
  • Response Time : 3ms (typical) (grey-to-grey)
  • Viewing Angle : 170°/ 160°
  • Color Support : 16.7 million colors
  • Color Gamut : 83.4%4
  • Refresh Rate : 120Hz (3D Capable)
  • Device Type : Widescreen Flat Panel Display
    • Video Connectivity : DVI x 1, HDMI x 1
    • Audio Connectivity : Yes; Audio In and Out (2.0)
    • USB Ports : Yes: 4 USB 2.0
    • User Input / Controls : Touch Capacitive OSD Buttons
Thanks
  Quote FrankW Quote  Post ReplyReply bullet Posted: 28 Jun 2012 at 12:30pm
Hi belaflek73,
I don't know anything about that monitor. If I was buying a 3D monitor then I would be looking at the Asus VG236H 120Hz 3D Vision LCD Monitor. It is $40 cheaper on Amazon. We do have some 3D users on the forum and they would have a better idea than I do. I am not a fan of 3D.
Onkel_Ken View Drop Down
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 10 Jun 2013 at 9:16am
Good thread. I need to upgrade my monitor some day and this thread is an informative read.
HAF 932 i7 920 OC 3.60 V8
EVGA GTX Titan SC 6GB VRAM
RAM 12GB Corsair Vengeance
1KW Corsair PS 300GB VelociRaptor
Western Digital 500GB 1TB BU
EVGA X58 Fatality X-Fi Champion
xii View Drop Down
  Quote xii Quote  Post ReplyReply bullet Posted: 10 Jun 2013 at 9:17am
Indeed.
mw2freak1111 View Drop Down
  Quote mw2freak1111 Quote  Post ReplyReply bullet Posted: 17 Jun 2013 at 7:44pm
Does anyone know of a good 23" or 24" monitor for $130 or less? maybe 5ms and less.
Thanks
jfox225 View Drop Down
  Quote jfox225 Quote  Post ReplyReply bullet Posted: 27 Jun 2013 at 1:36pm
Thanks
I picked up this one from some recommendations I've seen around here. $137 after rebate.
haight12 View Drop Down
  Quote haight12 Quote  Post ReplyReply bullet Posted: 07 Jul 2013 at 4:45pm
Just wondering if anyone has any experience with the 30" Dell U3011 or U3014?
I am trying to decide which one to get and I know each have their pluses and minuses.
Nomad1970 View Drop Down
  Quote Nomad1970 Quote  Post ReplyReply bullet Posted: 07 Jul 2013 at 5:17pm
A few of us bought U3014s, thread is here
http://www.digitalstormonline.com/forums/bought-dell-ultrasharp-u3014-update-pics-tidf19987/
My Precious:
C.M. 942 HAF X
i7 3930K @4.17GHz
Noctura NH-D14 SE2011
ASUS Sabertooth X79
16GB DDR3 1600MHz
1050W Corsair
240GB Corsair SSD
1TB W.D. HD
2 x GTX 670 4GB
<br
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 07 Jul 2013 at 5:17pm
Originally posted by haight12
Just wondering if anyone has any experience with the 30" Dell U3011 or U3014?I am trying to decide which one to get and I know each have their pluses and minuses.
Storm Trooper
i5 3570k
Ordered: 11-27-12
Stage 1: 11-29-12
Stage 2: 12-2-12
Stage 3: 12-2-12
Stage 4: 12-4-12
Stage 5: 12-4-12
Stage 6: 12-10-12
Stage 7: 12-12-12
Judist View Drop Down
  Quote Judist Quote  Post ReplyReply bullet Posted: 01 Jan 2014 at 4:15pm
I have 3 BenQ XL2420TE monitors. Roughly $300 a pop and worth every penny.
144hz, 1ms, 1920x1080. The stands are solid, easy to adjust, full portrait support. No dead pixels on arrival. Linus' has a good review on Tube if your interested.
If you prefer 27" they offer the XL2720T @ roughly $450
Edited by Judist - 08 Jan 2014 at 8:41pm
Nav View Drop Down
Moderator Group
Moderator Group
Digital Storm Employee
  Quote Nav Quote  Post ReplyReply bullet Posted: 07 Feb 2014 at 10:39am
Working on updating this thread!
UffDa View Drop Down
  Quote UffDa Quote  Post ReplyReply bullet Posted: 03 Apr 2014 at 8:14pm
Originally posted by Judist
I have 3 BenQ XL2420TE monitors. Roughly $300 a pop and worth every penny.144hz, 1ms, 1920x1080. The stands are solid, easy to adjust, full portrait support. No dead pixels on arrival. Linus' has a good review on Tube if your interested.If you prefer 27" they offer the XL2720T @ roughly $450
Interesting to note, their newer version is about $377 on Amazon. Looks like they've caught on!
I read an article that states the ASUS competitor to this is cheap in America and expensive in Europe...and the BenQ is the other way around.
Since I just ordered a LVL4 ODE, I have been agonizing over monitors and these BenQ's are getting great ratings (like the ASUS ones that DS offers - VG248QE).
DustyRH View Drop Down
  Quote DustyRH Quote  Post ReplyReply bullet Posted: 15 Apr 2014 at 8:44pm
Anybody seen, tried or ordered the 24 inch Asus Gsync? What do you think about it?
  Quote UffDa Quote  Post ReplyReply bullet Posted: 16 Apr 2014 at 12:47pm
I own the VG248QE. It supports GSync but does not have it installed.
In fact, I just did a search and cannot find a GSync ASUS that is sold from the OEM...the only ones are those that were purchased by someone else (like DigitalStorm) and retrofitted with the G-Sync kit.
I don't see one for offer on the DS site yet. I have little doubt it will be soon though!
i7 4930K 4.3GHz OC
ASUS Rampage IV Extreme
32GB DDR3 1866MHz Corsair Vengeance Pro
256GB SSD Samsung 840 Pro
2TB WD Caviar
2xSLI GeForce GTX 780 3GB EVGA Superclocked
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 16 Apr 2014 at 1:53pm
See if this helps... Looks like a back order.
http://www.digitalstormonline.com/nvidia-g-sync.asp
  Quote UffDa Quote  Post ReplyReply bullet Posted: 16 Apr 2014 at 4:01pm
By the way, while I have not seen one with my own eyes, I understand the technology they are pushing here. From what I have read it is legit and will likely be a very positive experience.
NVidia charges $200 for the DIY kit, so that's your base price point for upgrading a capable monitor. I suspect the price will come down as NVidia is able to convince some OEMs to integrate it into some monitors early on. However, let's face it, it's a niche product...so the price point makes sense and is likely to not drop a lot.
i7 4930K 4.3GHz OC
2TB WD Caviar
Roykirk View Drop Down
  Quote Roykirk Quote  Post ReplyReply bullet Posted: 02 May 2014 at 3:10pm
Would G-Sync work with a laptop (Krypton) equipped with an 880M pushing signal out over an HDMI connection?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 02 May 2014 at 3:18pm
I believe Gsync requires a displayport connections.
  Quote Roykirk Quote  Post ReplyReply bullet Posted: 02 May 2014 at 10:29pm
That works.  Krypton has both DisplayPort and mini-DisplayPort. Big%20Smile
m303803 View Drop Down
  Quote m303803 Quote  Post ReplyReply bullet Posted: 05 May 2014 at 3:06am
Hey - so i'm totally excited.  Just got my new (and first) DS system up and running.Drooling  I'll post about that experience and how great it's been later.  This is specific to monitors.  I want to build a cockpit simulator and have a 3 TV setup.  Specs for my system are below.  As i write this i am displayed on 1 46" Samsung LCD TV and the output is great.  The Sim Experience w/ FSX Acceleration turned on high everything is amazing.  I was hoping to now expand this to 3 Televisions.  This TV is 6 years old and my normal entertainment one, so i planned on buying 3 new ones all of the same brand.  Having a slim boarder is important to me to reduce field of view blockages.  Question: what would you guys recommend ? I don't see the need to spend a ton of money per TV since they all seem to be pretty good and cheap now-a-days.  Also - what cords and/or software would i need to buy in order to make this 3 screen setup happen ? I'm liking the 46" for height and will likely buy 3 of those.  Thanks!
System Configuration:
Chassis Model: Special Deal Hot Seller - Digital Storm ODE V3
Processor: Intel Core i7 4770K 3.50 GHz (Unlocked CPU) (Quad Core)
Motherboard: ASUS Z87-C (Intel Z87 Chipset)
System Memory: 16GB DDR3 1600MHz Corsair Vengeance
Storage Set 1: 1x SSD (120GB Samsung 840 EVO)
Storage Set 3: - No Thanks
RAID Config: - No Thanks
RAID Card: - No Thanks
Graphics Card(s): 1x NVIDIA GeForce GTX 780 3GB (Includes PhysX)
HPC Processor: - No Thanks
Airflow Control: - No Thanks
OS Boost: Yes, Disable and tweak all of the non-crucial services on the operating system
FrankDDougherty View Drop Down
  Quote FrankDDougherty Quote  Post ReplyReply bullet Posted: 28 Jul 2014 at 1:29am
Thanks for this post skyR. I am planning to buy a new computer for my friend on his birthday. This really gives me an idea about the monitor. Big%20Smile
I have the best gaming laptop for under $1500.
 Post Reply Post Reply Page  <1 456
This page was generated in 0.3886719 seconds.
