RecommendationsPost Date: 2015-01-26 |
mjndigstm19
Newbie Joined: 26 Jan 2015 Online Status: Offline Posts: 4 |
Topic: Recommendations Posted: 26 Jan 2015 at 2:08pm |
I'm planning to buy a Slade in a few months with these settings
System Configuration: Chassis Model: Special Deal Hot Seller - Corsair Obsidian 550D Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: AMD FX-9370 (8 Core) (4.4GHz) (8 MB Cache) (Black Edition) Motherboard: FX Series CPU Compatible - ASUS Crosshair V Formula 990FX (AMD 990FX Chipset) System Memory: 32GB DDR3 2400MHz Corsair Dominator Platinum DHX (Extreme-Performance) Power Supply: 1500W Silverstone Strider ST1500 Expansion Bay: Hard Drive Hot Swap Bay (EZ-Rack) Optical Drive: Blu-Ray & DVD Writer/Reader (Burn + Play Blu-Ray & DVDs) (12x BD-R) Storage Set 1: 1x Storage (6TB Seagate) Storage Set 2: 2x Storage (1TB Western Digital - Black Edition) Storage Set 3: - No Thanks RAID Config: RAID 5: Performance + Drive Failure Protection (Recommended) (Requires 3 HDDs) RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x NVIDIA GeForce GTX TITAN Z 12GB (Includes PhysX) Sound Card: Creative Sound Blaster Z HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Corsair H110 280mm Radiator Liquid CPU Cooler (Extreme-Performance Edition) H20 Tube Color: - Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Upgrade All Fans to Corsair Airflow Performance Edition (Up to 6 Fans) Internal Lighting: Internal Chassis Lighting System (White) Airflow Control: - No Thanks Chassis Mods: Fan Blow-Holes: VREG/CPU & Graphics Card Area: Laser Cut and Mount a Side Window 140mm Fans Noise Reduction: Noise Suppression Package Stage 2 (Optimized Airflow & Fan Speeds with Noise Dampening Material) LaserMark: - No Thanks CPU Boost: Standard Intel Turbo Boost 2.0 Automatic Overclocking Graphics Boost: - No Thanks, Please do not overclock my video card(s) Memory Boost: - No Thanks, Please do not overclock my memory OS Boost: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 8.1 (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: Microsoft Office 365 Home Premium (5 Devices + 1 Year Subscription) (Digital Download Only) Game: - No Thanks Display: Asus 24 inch VG248QE Series (144Hz Refresh Rate) (Black) (1ms Response Time) (LED Backlight) Surge Shield: APC SurgeArrest Personal PER7 (7 Outlet) 120V Surge Protector Speakers: Logitech 2 Piece (Black Edition) Amplified Speaker Set Keyboard: CM Storm Devastator Bundle (Gaming Keyboard & Gaming Mouse) Mouse: - No Thanks NVIDIA SHIELD: - No Thanks Branded Gear: - No Thanks Priority Build: Please Prioritize: Ship Within Four Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) This is a Level 1 setting and $5000-$5500 is my budget. I'll be using this computer for gaming and only using one monitor. Is it a good setting? Any recommendations would be helpful since this is my first time ever configuring a computer. |
michaeljhuman
Quote Reply Posted: 26 Jan 2015 at 2:19pm |
With that budget, why an AMD CPU? I would go with a Haswell CPU. You could afford a 6 core if you want (12 total virtual cores.) For gaming you don't need a 6 core, so you can even go cheaper, but a 6 core might be nice in the future.
Power supply is excessive for a one GPU system IMO. Excessive even for a dual GPU system, I think I run closer to 1000 watts in my current PC and the new cards seem to use less power. Nothing wrong with future proofing or personal preference, but I would, personally, go a bit cheaper on the supply. You can live with 16 GB, but I would also choose 32 GB I would consider dual GTX 980 over Titan Z, but that's a personal choice. You could study some benchmarks and balance cost, vs any hassle with SLI vs. gaming performance Edited by michaeljhuman - 26 Jan 2015 at 2:21pm |
Quote Reply Posted: 26 Jan 2015 at 2:38pm |
This should suit you a bit better:
Configuration URL: https://www.digitalstormonline.com/configurator.asp?id=1138678 Specifications: Chassis Model: Special Deal Hot Seller - Corsair Obsidian 550D Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 4790K 4.0 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) Motherboard: ASUS Z97-PRO (Intel Z97 Chipset) (Features 802.11ac Wi-Fi Connectivity) System Memory: 16GB DDR3 2133MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 750W EVGA SuperNOVA Expansion Bay: - No Thanks Optical Drive: Blu-Ray & DVD Writer/Reader (Burn + Play Blu-Ray & DVDs) (12x BD-R) Storage Set 1: 1x SSD (512GB Samsung 850 PRO) Storage Set 2: 2x Storage (2TB Western Digital - Enterprise Edition) Storage Set 3: 2x Storage (2TB Western Digital - Enterprise Edition) RAID Config: RAID 5: Performance + Drive Failure Protection (Recommended) (Requires 3 HDDs) RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 980 4GB (Includes PhysX) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex 120mm Radiator Liquid CPU Cooler (High-Performance Edition) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: Noise Suppression Package Stage 1 (Optimized Airflow & Fan Speeds Only) LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 8.1 (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: Microsoft Office 365 Home Premium (5 Devices + 1 Year Subscription) (Digital Download Only) Game: - No Thanks Display: Asus 24 inch VG248QE Series (144Hz Refresh Rate) (Black) (1ms Response Time) (LED Backlight) Surge Shield: APC SurgeArrest Personal PER7 (7 Outlet) 120V Surge Protector Speakers: Logitech 2 Piece (Black Edition) Amplified Speaker Set Keyboard: CM Storm Devastator Bundle (Gaming Keyboard & Gaming Mouse) Mouse: - No Thanks Portable Gaming: - No Thanks Branded Gear: - No Thanks Priority Build: Please Prioritize: Ship Within Four Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) I'd encourage you to look at other monitors...dual GTX 980 graphics cards can support a lot more than a single 1080p monitor. Also, mechanical keyboards are very nice to type on or game with, so you may want to consider that. And the speakers you picked out, will work but won't be exceptional in any way. Search the forum for advice on these...there is plenty out there. |
mjndigstm19
Quote Reply Posted: 26 Jan 2015 at 9:26pm |
Thanks for your input. Definitely will look into that. |
Quote Reply Posted: 27 Jan 2015 at 5:24am |
Just to chime in... I would also go with the sli gtx 980 over the Titan Z. The sli 980 will be better performance and less power usage. The Titan Z is a great pick for a small form factor case that only allows a single card. Otherwise, the sli 980 is cheaper and more flexible. If your Titan Z goes bad and not covered by warranty, you'll be out a chunk of money. If a 980 fails, its cheaper to replace and gives you another to fall back on.
Plus, the Titan Z is still SLI, just on a single card. and it does have more vram, but not the 12gb some think, but 6 gb per gpu on the card. Vram doesn't stack in sli, so the Titan Z is 6gb usable and the sli 980 has 4 gb usable. I would also go with the i7-4790k cpu you were shown and the mobo to match. The Intel is a much better pick. AMD has more cores but doesn't utilize them as well as would be expected. Here's a link to help make the decision. http://cpu.userbenchmark.com/Compare/Intel-Core-i7-4790K-vs-AMD-FX-9370/2384vs2005 You can also drop the Chassis mod, side blow holes.... The 550D has two mounts/cutout already for fans if needed. The side acoustic panel is removable. Just an FYI.... Not sure in your case, but the 550D is sometimes selected for being the quietest case, but that's if the top and side acoustic panels stay on. The 280mm rad you selected will mount under the top,and require the top panel to remain off at all times for proper venting. Hope this helps. Edited by bprat22 - 27 Jan 2015 at 5:54am |
mjndigstm19
Quote Reply Posted: 27 Jan 2015 at 8:51am |
Thank you all for your inputs. It really helped me out a lot
