Hi Petard06..... Welcome to the forums.
For a water cooled system , your build is pretty much right on. The Hailstorm case is made for water cooling. You could save $300 by going to the 4 core 3820 chip, all that gaming will use, but drop oc'ing to stage 1. DS doesn't oc that chip as high as the 3930k.
To answer your question, for gaming several hours a day water cooling is more a luxury than a neccessity. It is nice if budget is there, but air cooling will do it just as good, with longevity and stability and alot easier to change parts if needed.
Here' a air cooled system to check out that will give you the same gaming, but is $1000 cheaper.
Config # 707542 Cost $ 2897
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 670 2GB (Includes PhysX)
The HafX case is the best for air cooling.
8GB ram is all gaming needs.
If you game on both monitors then the sli, 2x gtx670 will play BF3 on high settings real smooth, but struggle a bit on Ultra with everything turned up. For a single monitor the sli will max out gaming and stay 60fps or better.
If by chance you want the option to tri-sli, 3x gpu in the future, then the X79 Sabertooth and 3820 chip from your first build would be needed. Then you would start with Dreadnought level 3 and tweek the config and still save alot of $$$ with air.
Water cooling is great, and if its something you always wanted then your config is great.. This config saves money but is air cooling.
Hope this helps and best of luck.
Edited by bprat22 - 13 Jul 2012 at 9:27am
