Razer Blade vs x17
Post Date: 2012-06-18
Page  <12
redkulaid View Drop Down
  Quote redkulaid Quote  Post ReplyReply bullet Posted: 18 Jun 2012 at 5:55pm
Originally posted by Bosboi
Does the x17 come with an Optical port to connect to my toslink optical cable that came with my Astros?
Sorry I'm terrible with all these names for this stuff...
I went through the same thing. Took me awhile, but I found out the X17 dose not support DDL, which is what the astro mix amp requires for 7.1 audio and game to voice controls. It does have the S/PDIF Digital output, you just need the adapter(3$ on the net). I went with the Asus Xonar x3 usb audio card(35$ shipped or so), has the same port, and comes with the adapter, and supports DDL, so ill get the true 7.1 audio, and ill be able to do the game/voice controls on the mixamp. So ill have the mixamp hooked up via use(mic)and the digital cable into the usb sound card.
Hope that helps
Bosboi View Drop Down
  Quote Bosboi Quote  Post ReplyReply bullet Posted: 18 Jun 2012 at 6:26pm
Yeah I can't find it...
Can you give me a link for one of the $3 ones, please?
  Quote redkulaid Quote  Post ReplyReply bullet Posted: 18 Jun 2012 at 6:56pm
http://www.amazon.com/Recoton-Fiber-Optic-Toslink-Adapter/dp/B0002MQGRM/ref=sr_1_13?ie=UTF8&qid=1340070632&sr=8-13&keywords=S%2FPDIF+Digital+output+adapter
even better, its 1.04$, free shipping. Thats all you need for it to hook up to the mixamp, will be a 7.1, but you wont be able to control the voice/game like on the xbox 360 etc.
  Quote Bosboi Quote  Post ReplyReply bullet Posted: 18 Jun 2012 at 7:41pm
Okay so I ordered the Asus because I want the Game/Voice control.
But how do I set it up on my computer?
  Quote redkulaid Quote  Post ReplyReply bullet Posted: 18 Jun 2012 at 8:01pm
same way. The sound card plugs in via usb, come with the adapter you need to run the digital to the mix amp. Then mix amp hooked up usb to(for mic), and then mx amp to headset. The sound card just takes the digital input for a true 7.1 and the option to control the voice/game, since it supports dolby digital live.
  Quote Bosboi Quote  Post ReplyReply bullet Posted: 19 Jun 2012 at 5:02pm
Is the Asus even good with the Astros at all?
Because if they are not good then I'm really.going to get pissed...
Getting a computer should be less stressful than this is right now...
I just had to drop another $50 and I really don't have this money...
I am going to be in so much debt with my parents...
And just for the record I'm not like really in debt.
I'm actually only a teenager but don't just have all the money in the world...
(Wish I did though : ) )
  Quote redkulaid Quote  Post ReplyReply bullet Posted: 19 Jun 2012 at 5:32pm
Its one of the best usb audio cards, and even better considering the price. 99.9% of laptops use the onboard audio card, and wont support DDL, even most desktops wont unless you buy an audio card. I have not used it yet, since there is no point on this netbook, but I did read a lot of reviews, and other sites then recommended this for the Astro A40. Also remember, the astro is made for xbox/ps3 in mind, not a pc. While we can use it, they are not made for computers like they are for game console. You can just forget the audio card, but you wont be able to control the mix amp features besides volume, and even then, you can do that on the cord for the headset
  Quote Bosboi Quote  Post ReplyReply bullet Posted: 20 Jun 2012 at 5:52pm
I just got my computer!
LOVE IT!
But just one question,
Where do I find the AMD Radeon 7970m drivers?
And is it normal for it to say when trying to boot up Counter Strike: Source that it can't find my graphics card?
  Quote redkulaid Quote  Post ReplyReply bullet Posted: 20 Jun 2012 at 6:31pm
LOVE IT!
The drivers are in beta, so look around. Newest ones are 12.7. AMD put the HD7000m series on their site for support, so hopefully soon there will be official drivers, and performance will only get better.
  Quote Bosboi Quote  Post ReplyReply bullet Posted: 20 Jun 2012 at 6:44pm
Also, what do you guys recommend for an antivirus software?
xii View Drop Down
  Quote xii Quote  Post ReplyReply bullet Posted: 20 Jun 2012 at 8:10pm
Eset.
Orange7 View Drop Down
  Quote Orange7 Quote  Post ReplyReply bullet Posted: 21 Jun 2012 at 9:14am
Malwarebytes. It's fast, it's free, and it catches everything. It found 103 pieces of malware/adware/spyware/etc. that Norton missed on an old computer that I was rehabilitating.
Edited by Orange7 - 21 Jun 2012 at 9:14am
DS xm15 Stage 4
i7-3820 (2.7GHz/3.7GHz)
16GB 1600MHz DDR3
GT 630, 1GB
240GB Intel 520
DSW View Drop Down
  Quote DSW Quote  Post ReplyReply bullet Posted: 21 Jun 2012 at 9:33am
ESET and Kaspersky are both solid. I used to like BitDefender, but they seem to be getting intrusive and slipping.
For the free route I favor Malware Bytes and, surprisingly, MSE. Microsoft has gotten their act together and has an antivirus solution with a very small footprint.
I advocate using multiple programs, because one will often catch what the other misses.
Tidgxor View Drop Down
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 21 Jun 2012 at 9:53am
I have used one free program or the other for about the past.. 17 years, and haven't had a virus since 95 Smile Currently using Avast! but I can't really vouch for its extreme effectiveness, as I never have needed it save for the occasional caught trojan when I was searching through the more nefarious areas of the interwebs, haha.
xii View Drop Down
  Quote xii Quote  Post ReplyReply bullet Posted: 21 Jun 2012 at 9:58am
However, Esets package also offers firewall and system integration.
 Post Reply Post Reply Page  <12
