Rate this system
Post Date: 2015-04-19
yodachoda View Drop Down
  Quote yodachoda Quote  Post ReplyReply bullet Topic: Rate this system
    Posted: 19 Apr 2015 at 2:50pm
~$2000
Play all modern games at highest settings and good frames per second.
Gaming mostly
Chassis Model: Special Deal Hot Seller - Corsair Graphite 230T (Black - No Window)
Motherboard: GIGABYTE G1.Sniper Z97 (Intel Z97 Chipset) (Onboard Creative Sound)
System Memory: 16GB DDR3 1866MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested)
Power Supply: 750W EVGA SuperNOVA
Storage Set 1: 1x SSD (250GB Samsung 850 EVO)
Storage Set 2: - No Thanks
Storage Set 3: - No Thanks
RAID Config: - No Thanks
RAID Card: - No Thanks
Graphics Card(s): 1x NVIDIA GeForce GTX 970 4GB (ASUS Strix Edition)
HPC Processor: - No Thanks
Airflow Control: - No Thanks
Hi all, will this system be able to play any game currently on the market at the highest settings with reasonable (i.e. playable) frames per second? I'm thinking at least 50ish FPS.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 19 Apr 2015 at 4:17pm
Hi yodachoda,
You have made some good picks.
1. I would select the 256 850 Pro over the Evo for $48.
2. The 970 GPU will play most games with good FPS at 1920 x 1080 resolution. But the ratings are averages and you might fall back a bit with some scenes. Probably not enough to worry about. The 980 will give you about a 15% boost over the 970 but at a cost penalty. I suggest you go to AnandTech and check out their Bench test for GPUs. That will give you a good idea of what to expect from your 970. You can even compare the 970 performance to the 980 with many different games.
Edited by FrankW - 19 Apr 2015 at 4:19pm
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 19 Apr 2015 at 4:18pm
Looks like a high-end Vanquish Ultimate...looks good to me.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 19 Apr 2015 at 4:22pm
Noname makes a good point. If you go with the 970 GPU you might save some money going with the Vanquish level 4.
Gunner GzR View Drop Down
  Quote Gunner GzR Quote  Post ReplyReply bullet Posted: 19 Apr 2015 at 5:26pm
i would bump up the power supply but it is not necessary just a thought
 View Drop Down
  Quote  Quote  Post ReplyReply bullet Posted: 19 Apr 2015 at 5:36pm
Extra PSU is not necessary for a system like this unless he'll be putting a second GPU as well as a TV tuner card or other peripherals that draw a lot of power. This should be good enough for a system with SLI GTX 970's.
Clay View Drop Down
  Quote Clay Quote  Post ReplyReply bullet Posted: 04 May 2015 at 6:46pm
Very nice rig for that price.
I7 13700KF 5.4hz
ASUS Prime z790 MoBo
ASUS Dual 4070
32g ram@5200
850 Gold PSU
1TB SSD 2TB SSD
27" ASUS Monitor 144hz
Razer Ornata Chroma Keyboard
Razer Basilisk V2 Mouse
Nari Ultimate Headset
  Quote Gunner GzR Quote  Post ReplyReply bullet Posted: 05 May 2015 at 12:48am
Yea was what I was thinking about. Down the line if he wanted to upgrade.
