Ram and Antivirus/spyware/malwarePost Date: 2013-05-25 |
crispy
Newbie Joined: 26 Apr 2013 Online Status: Offline Posts: 24 |
Topic: Ram and Antivirus/spyware/malware Posted: 25 May 2013 at 9:11am |
Ok so im a bit paranoid or just plain uninformed but I currently have microsoft security essentials, malwarebytes(free), Superantispyware(free) and Norton 60day trial.
I've recently wiped my pc and started over only to find out norton was available so i thought id try it. Turns out instead of using 1.50+- gb of ram now its using around 2.50gb I plan to eventually buy a paid version of something i like but not sure exactly what i need to keep and let go, and if possible not use much ram.. any suggestions? Also i downloaded but not installed avast. Thx! |
crispy
Quote Reply Posted: 25 May 2013 at 9:14am |
side note i have 8gb of the adata gaming ram from ds Oh and also sometimes ill restart and it will be back to 1.5 gb ram use. I should always have those apps(under hidden icons)running correct?
Orange7
Senior Member Joined: 24 Apr 2012 Online Status: Offline Posts: 776 |
Quote Reply Posted: 25 May 2013 at 7:12pm |
I would say that if you were going to pay, the best out there is ESET, and if you just want free, Malwarebytes and Avast should keep everything off, and as you probably know, the resources held by them are insignificant when compared to Norton.
There is another thread on antivirus software (links below), where you could check out all of the arguments for each, but those are the major contenders. http://www.digitalstormonline.com/forums/best-paid-anti-virus-tidf19848/ http://www.digitalstormonline.com/forums/antivirus-software-tidf19180/ I'd also recommend reading the MaximumPC article that I mention in the second one. Edited by Orange7 - 25 May 2013 at 7:16pm |
DS xm15 Stage 4
i7-3820 (2.7GHz/3.7GHz) 16GB 1600MHz DDR3 GT 630, 1GB 240GB Intel 520 |
Quote Reply Posted: 25 May 2013 at 8:36pm |
Microsoft Security Essentials works pretty good...at least for me.
Onkel_Ken
DS Veteran Joined: 17 Dec 2008 Online Status: Offline Posts: 2961 |
Quote Reply Posted: 10 Jun 2013 at 9:26am |
I have been using Kaspersky internet Security for several years and have been happy with it.
retirednavysnipe
Senior Member Joined: 06 Apr 2012 Online Status: Offline Posts: 606 |
Quote Reply Posted: 11 Jun 2013 at 7:55am |
I use Trend Micro and haven't had any issue so far. (Knock on Wood)
Hailstorm Black Ops
I7 3930K 4.5GHZ 16GB 1600MHZ ram 2 x GTX 680 120 GB SSD, 1 TB hardrive Fully liquid cooled CPU, GPU and chipset. |
TechnoNinja
Newbie Joined: 13 Jun 2013 Online Status: Offline Posts: 1 |
Quote Reply Posted: 13 Jun 2013 at 12:15am |
according to the test done, bitdefender and trendmicro are the best out of all the antivirus out there. those are paid softwares btw. I use bitdefender and it really is awesome. You can get more info for bitdefender at http://www.hopreviews.com/reviews/bitdefender-total-security-2013/ if you need. but from what you have already, i think it is pretty good. I've used them before.
Edited by TechnoNinja - 18 Jun 2013 at 9:59pm |
Captain Ahoge
Moderator Group Digital Storm Employee Joined: 04 Jan 2012 Online Status: Offline Posts: 57 |
Quote Reply Posted: 14 Jun 2013 at 5:03pm |
I personally use what I like to call my "four-hit combo" of:
1. Common sense 2. Avast! 3. Malwarebytes 4. AdBlock Plus on Chrome/ABP + NoScript on FireFox. |
Steam ID: CaptainAhoge
